02-03-2017, 01:17 PM | #1 |
210
Rep 374
Drives: 2022 X3M Comp
Michelin PSS
I live in NJ expecting my F80 next week or so. What is the ideal temperature to use these tires. Tempature in NJ is around low 40'. I am not expecting to buy winters tires until end of the year. I have read that 40degree is fine but is there anything i should know.
02-04-2017, 12:01 AM | #4 |
210
Rep 374
02-04-2017, 08:48 AM | #5 |
1110
Rep 2,007
DON'T PUSH THE CAR AT ALL IN THE COLD WITH THOSE TIRES. Any aggressive throttle and the rear wheels will spin. I'm also very cautious pushing into corners because the grip is simply not there.
Wet is even worse. Drive it like a normal car and you will be fine. You are just getting your M, so telling you to drive it like a normal car may sound silly. In the summer, when those same tires stick like GLUE, driving normal is very difficult. That peddle on the right is intoxicating to say the least. Good luck with the new ride. |
f80NJ17210.00 |
02-04-2017, 09:48 AM | #6 | |
256
Rep 928
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT |
02-04-2017, 10:22 AM | #7 |
728
Rep 1,250
02-04-2017, 10:23 AM | #8 |
746
Rep 1,247
Don't drive under 32... the compound can crack when exposed to those temperatures.
I usually change back to summer tires in mid March, just to be safe. Sometimes early April. |
02-04-2017, 12:28 PM | #9 |
197
Rep 479
I call it BS. Past my 7 years I drove all my bimmers during NYC winters with summer tires on. Sometimes in - degrees F.
02-04-2017, 04:10 PM | #10 | |
746
Rep 1,247
1. They are super dangerous to be driving around in <32°F 2. They are prone to stress cracks below freezing You can contact the manufacturer yourself, if you please. And I would find it hard to understand why you would think it's okay to drive w/ summer tires on when it usually snows quite a bit up here. Unless you never drive in the snow, that is. |
Professor///M818.50 |
02-05-2017, 12:35 PM | #11 |
728
Rep 1,250
Virtually any car is un-driveable w summer tires in snow , especially the colder the temp is - I had a Mitsubishi evo x that had an awesome all wheel drive system which included a snow mode setting and if I had on my summer tires in snow I couldn't drive above 5-10 mph - not to mention you will significantly shorten the life of the tires
02-05-2017, 02:32 PM | #13 |
21117
Rep 20,741
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
