02-02-2017, 09:51 PM | #1 |
Rep 4
Odd Tire wear?
Long time lurker, and 2011 135i owner here. I guess I wore out this set of tires, since they just went flat. Anyone seen this type of tire wear before?
02-02-2017, 10:33 PM | #2 |
Ex '87 Carrera
246
Rep 1,259
Looks like someone needs to make more regular tire inspections. Those things are well and truly shot, and it didn't happen overnight...
ianc |
02-03-2017, 08:01 AM | #3 |
Loves me some MHD!
1858
Rep 1,719
What alignment setting were you supposed to be on, and did you get it aligned when the new tires went on?
front or rear? 245/35 so I'm guessing rear kind of tough to tell from the small area shown in the pics, but could be wearing against suspension, could be toe or camber is off. Assuming an all stock configuration I'd suggest getting a good (4 wheel full spec, not a "toe-n-go" job) from a respectable shop and having them verify all the suspension bits are in good shape- no worn bushings etc. And agree with above- inspect your bits more often
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
02-06-2017, 02:38 PM | #4 |
Rep 4
02-06-2017, 02:44 PM | #5 | |
Rep 4
Tires are down to the wear bars all around, but this damage wasn't visible without removing the tires, or getting under the car. I typically wouldn't be that thorough for a car that doesn't see any track time. I think the wear may be caused by suspension squat under acceleration. The alignment check will yield more clues. |
02-06-2017, 05:54 PM | #6 |
1Addict
3233
Rep 7,894
Pics aren't working. Where's the wear?
02-06-2017, 07:48 PM | #7 |
Loves me some MHD!
1858
Rep 1,719
pics still work for me, try quoting the post to get the url ánd opening up the imwges directly from photobucket
1and1
02-17-2017, 07:34 AM | #8 |
1014
Rep 638
By the way another reason to ditch RFT's excessive wear, I was getting ridiculous wear on 2 sets of tires, winters and summers,
went to go flats, better ride, grip, traction, and WEAR is phenomenal |
02-17-2017, 07:42 AM | #9 |
Loves me some MHD!
1858
Rep 1,719
chuckle.. "go flats"
love it, hadn't heard that before
1and1
