01-08-2017, 04:22 PM | #1 |
384
Rep 548
Fabworx c@tless dp w/ Eisenmann sport mufflers
Hey guys... just wanted to post up some pics and a video of an install I did yesterday on one of our fellow forum members car
DP to be installed: Fabworx Cons: Fit was slightly off in a few areas (lower 02 sensor bugs are positioned way lower than stock position which gives hardly any slack to the cable once you plug it in, upper 02 sensors sit slightly sunken in which doesn't allow you to install the heat gaskets, passenger side dp bracket was slightly off, driver side dp didn't mate perfectly flush with the turbo) which made install time a bit longer but with a few adjustments I was able to get them to fit with no exhaust leaks. Pros: Car sounds and performs great! On to the fun stuff... |
01-09-2017, 01:33 PM | #4 | |
384
Rep 548
In the process of removing a blown wavetrac diff on a 680hp 335 here in Downey as I type... |
01-11-2017, 12:21 AM | #6 |
384
Rep 548
Had the chance to work on another M5 earlier today... this time around i installed RK mandrel bent down pipes. Review coming soon for that install.
01-11-2017, 12:58 AM | #7 |
644
Rep 2,039
01-11-2017, 11:56 AM | #9 |
Perennial PFC
338
Rep 1,275
That's very disappointing, I was looking forward to buying those and putting them on this winter. In spite of the bad fit, I hope they're able to work for you? I thought the way he described the Fabworx DPs was bad enough, and was waiting for a glowing report on RK.
e46m3lol383.50 |
01-12-2017, 05:34 AM | #10 |
450
Rep 1,519
Just got full Eisenmann setup with fabworx dp. Lol.
TheHouseWon644.00 e46m3lol383.50 |
01-12-2017, 08:10 AM | #11 |
644
Rep 2,039
01-12-2017, 08:40 AM | #12 | |
450
Rep 1,519
Dp is no problem on fitment we all use fabworx Dp The fitment is Perfect!!!!!!! And quality is excellent It will sound crazy as i will take the valves that open and close off so this will sound better than the Race Exhaust and to top it off with fabworx dp. It will sound really Insane!!!!! I have full Fabworx 3.5" custom made exhaust no bends like Eisenmann but totally different sound also. The Eisenmann has a deep sound which i love this will be perfect for 700hp car. |
e46m3lol383.50 |
01-12-2017, 09:18 AM | #13 | |
644
Rep 2,039
e46m3lol383.50 |
01-12-2017, 09:19 AM | #14 | ||
450
Rep 1,519
01-12-2017, 09:53 AM | #15 |
Perennial PFC
338
Rep 1,275
If you use a magnifying glass on post #10 I think you'll see the lower O2 bung in the proper location. I'm also concerned with the sunken level of the upper O2 bungs not allowing the heat gasket installation. Did he manage to get his gasket installed on his car?
e46m3lol383.50 |
01-12-2017, 10:57 AM | #16 |
Perennial PFC
338
Rep 1,275
I wonder if Fabworx did as a few other DP makers did in the early versions of the DPs and put those lower O2 bungs in the easier straight section of pipe? With all the heat in that 'hotV' part of the engine, I don't want any wiring routed other than the stock location. That's the reason I definitely also want the heat gaskets for the upper O2 bungs in place. They are very close to the DMEs and I don't want more radiant heat on the DMEs from openings in the heat shielding. Adding to that, if the lower O2 bungs are not in the stock location, aren't those openings in the heat shielding allowing even more heat out under the DMEs?
e46m3lol383.50 |
01-12-2017, 11:09 AM | #17 | ||
Hide! My wife's coming!
813
Rep 2,816
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
e46m3lol383.50 |
01-12-2017, 11:10 AM | #18 | |
24
Rep 124
Are you kidding me? we dont "all use fabworx dp". some of us use fabworx cause you can pick them up for $6xx brand new on ebay. Most of us spend the extra penny and pick up a set of AMS. http://www.ebay.com/itm/BMW-M5-M6-F0...tYBU9l&vxp=mtr Fabworx lists these every week for this starting bid and usually there is no bids so u can get them for that price. |
01-12-2017, 11:27 AM | #19 | |
450
Rep 1,519
AllMotor has Fabworx also 2 of the fastest dct cars running that i have Full Fabworx manual 800hp Manny M5 has fabworx dp mix with Full Meisterschaft exhaust 900/980 So to Shut this A_ _ hole aka ----LA-m55 -----crying about nonsense do your research first its not all about brands. I think u may gotten bullied back in the day. Sit down habibi. |
01-12-2017, 11:38 AM | #20 | |
24
Rep 124
01-12-2017, 11:40 AM | #21 | |
24
Rep 124
By the way I'll smoke your smurf mobile. |
