12-27-2016, 07:24 AM | #1 |
74
Rep 188
M5 F10 - charge pipes leaking already
I have a (2016) M5 f10 ans wanted to upgrade my charge pipes so i can easily fit meth 2017 and get the benefit of a larger bore boost pipe.. But discovered the "once only" clips not doing there job as usual and saw one side was leaking, just thought id let others know as you could be loosing boost.
While i was there i decided to wrap the coolant pipes to help reduce heat transfer from charge pipes to the coolant, here's some pics NEXT MODS are brake coolers, as the standard brakes are virtually useless once you hit the track, and potentially going to fabricate carbon cooling plates to then resale.. Watch this space - |
12-27-2016, 07:26 AM | #2 |
3323
Rep 8,083
Neat wrap job! Lol
financenick73.50 |
12-27-2016, 10:51 AM | #4 |
74
Rep 188
I used this to wrap, www.ebay.co.uk/itm/261335400501?_trksid=p2057872 will be using Aquamist for the meth, have been to see the owner Richard and saw where they are manufactured - ill be doing a separate post on Aquamist as we were given a demo in the factory of how their system works. Is by far the best kit out there currently, no other meth kit comes close !!
