      12-07-2016, 09:21 AM   #1
doublevanosrc
Loves his G20
doublevanosrc's Avatar
265
Drives: 2020 330ix M sport
2013 BMW  [0.00]
Fix for rusty rear rotors?
So I'm debating changing out my rear rotors since they are really rusty and are a sore sight on the car. I tried to get the stealer to swap them out twice and they didn't budge claiming they were "within spec". So I assume the new oem ones will end up rusty too, any aftermarket recommendations that don't rust?
*When i mean rust I refer to the hub center part not the braking surface which always rust after a carwash or rain.
2020 330ix-Msport
Past-
2013 135i
2011 135i
      12-07-2016, 10:10 AM   #2
Matticus91
Matticus91's Avatar
Drives: 2013 135i
Just sand it down to metal and paint it with some high-temp paint. There's tons of DIY's on this.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq
      12-07-2016, 10:37 AM   #3
doublevanosrc
Loves his G20
265
2013 BMW  [0.00]
Yeah I was trying to avoid that and just buy some that don't rust. That was the first thing that came to mind.
2020 330ix-Msport
Past-
2013 135i
2011 135i
      12-07-2016, 11:41 AM   #4
Matticus91
Matticus91's Avatar
Drives: 2013 135i
The OEM Brembo's shouldn't rust if they're handled/installed and maintained correctly. My originals that I swapped out in June still looked good, just a little white film oxidation.
If they've rusted though you'll just have to refinish them.
      12-08-2016, 08:56 AM   #5
NVHoo
161
Drives: 2011 128i red convertible
Agree
Brembos are zinc plated so they won't rust anywhere on the rotor that does not touch the disk pad. The key is to make sure the replacements have some type of electrocoating. You can get black, colors, or metal finish from various suppliers.
I get cross-drilled when I replace my OEMs because I like the look. Some racing enthusiasts may tell you to avoid cross-drilled because they might crack but I've seen no evidence of this when bought from reputable manufacturers and the cars are not tracked. Where you can run into trouble is parts dealers who buy low end solid rotors and then send them to a local machine shop to drill. Many cars have cross-drilled as OEM.
      12-08-2016, 09:19 AM   #6
Matticus91
Matticus91's Avatar
Drives: 2013 135i
I think you replied to the wrong guy haha. As for the cross-drilled rotors, they are technically weaker and are easier to warp, but unless you're actually doing hard-running trackdays you won't have any issues with most brands. If you're looking for performance, the OEM 2-piece Brembos are the way to go, hands-down.
      12-08-2016, 10:24 AM   #7
Vigilante375
Drives: 2012 AW 6M 135i
I'm pretty sure all hubs are going to have some type of rust on them. And I believe its a surface rust rather than a rust that is going to penetrate it. It makes no sense to replace something that just has surface rust.
You will be save a lot of money by just taking the tires off, getting the surface rust off by sand paper, then painting it with the appropriate paint. Something that will stop the rust from ever forming again.
Go look at any vehicle that has unpainted hubs and they will look like yours. Its honestly nothing to worry about. Because if it was, then manufacturers would have done something many, many years ago.
      12-13-2016, 09:27 AM   #8
Matticus91
Matticus91's Avatar
Drives: 2013 135i
Originally Posted by Vigilante375 View Post
You will be save a lot of money by just taking the WHEELS off...
FTFY
