11-18-2016, 12:14 PM | #1 |
Master of my own domain!!
153
Rep 1,049
M6 Wheels
Anyone try the style 433 wheels on the F82? Specs are as follows:
Fronts are 9.5x20 ET:31, Rears are 10.5x20 ET19 Think they would fit with rubber? |
11-18-2016, 02:57 PM | #3 | |
6586
Rep 5,305
The front might rub on the inside depending on the tire and suspension you have. And the wheel will be pretty sunken in. I suggest a 5mm or 10mm spacer on the front wheel to bring it out. This will give you ample clearance and a better flushed look. The rears will be practically impossible to work. You will need an ungodly amount of camber and a impossibly stretched tire to fit it. Check out how aggressive the rear fitment is on this F80; your M6 wheel will stick out 5mm more than that. |
Singh21139.00 |
