ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      04-06-2008, 06:23 PM   #1
dekaliber
75
Drives: '07 Z4MC, '11 JCW, '18 Z06
Spacers on Z4
I've been considering spacers to widen the stance of the back tires on my Z4. They're SP OEM rims (18x8.5 ET 50) and they don't quite fill out the wheel well as much as I'd like. Ideally I'd like them to be flush (or a little bit inside) with the fender.
Have any others with a Z4 or Z4C used spacers with success? Will it require a suspension drop to look good? Are there any issues that may result that I should be aware of (e.g. handling changes, excessive bearing wear, tread wear, ...wheels falling off!, etc.) and are there known solutions to these problems? What brand/size would you suggest?
      04-07-2008, 01:42 AM   #2
Zeddy4Me
Zeddy4Me's Avatar
South Korea
24
Drives: 09, AW E90 M3 6MT
Have 20mm spacers on the rear. I'm running 275/30 19's. Fills up the gap and wheel wheels flush and perfect. I also have H&R's...
      04-07-2008, 06:22 PM   #3
dekaliber
75
Coilovers or springs? (I am n00b)
      04-07-2008, 06:46 PM   #4
BimmerZealot
61
Drives: 2019 BMW X3 xDrive30i
H&R makes both so that is a legitimate question, if I remember correctly Zeddy4Me is running H&R springs
      04-08-2008, 02:32 AM   #5
Zeddy4Me
Zeddy4Me's Avatar
South Korea
24
BimmerZealot,
You're correct! hehe...
Just Springs for now. Perfect drop, great ride and no noise. I'm probably gonna do the KW's in the future...
      04-08-2008, 10:33 AM   #6
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
If you are planning to track your car, then it is best not to use spacers. You be asking for trouble if you do.
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      04-08-2008, 11:56 AM   #7
dekaliber
75
How come?
      04-08-2008, 12:16 PM   #8
AtoB
AtoB's Avatar
Drives: Z4M
Originally Posted by dekaliber View Post
How come?
i'm guessing because they can crack under hard use.
i had spacers on my old 3.0... they really helped the cars stance.
performance wise... nothing i noticed. my only mistake was not getting an alignment after i installed them... my tires were garbage in 3 months.
      04-08-2008, 03:05 PM   #9
Zeddy4Me
Zeddy4Me's Avatar
South Korea
24
YES YES YES... Get that alignment right after you get your wheels and springs put on. Don't wait the for mythical "settling in" period. Make sure they use the Hunter system...
      04-08-2008, 06:15 PM   #10
runnerx
runnerx's Avatar
How come?
The use of spacers is prohibited on a lot of tracks for safety reasons
1. it may crack
2. it puts more wear on the wheel bearings
3. they can get loose
2009 BMW X5 4.8i
      04-08-2008, 11:37 PM   #11
dekaliber
75
Damn. Sounds like the right way to go is wider tires?
      04-09-2008, 12:16 AM   #12
BimmerZealot
61
Wider wheels + tires
      04-09-2008, 12:17 AM   #13
dekaliber
75
Oops -- wider wheels is what I meant!
zpost
