10-31-2016, 09:15 PM | #1 |
330
Rep 984
Garage Clean Up Goodies Sale!
Hey everyone! Decided to finally clean through my garage of things that I have or bought in the past few years in excess and no longer need. All can be picked up from Dundas Valley in the early mornings or evenings or in the CBD during work hours 9am-6pm. Can post at buyer's expense.
OEM n54 twin turbos (the front turbo seals are leaking, the rear turbo is totally fine, wastegate rattle is a fair bit but is fixed with wastegate rattle fix on a jb4 or mhd. Can also be used as core exchange for upgraded turbos such as hexons which are valued at 500USD). 400 firm. 6 x OEM Bosch Ignition Coils. Used for 80k kms. Worked perfectly fine when I tuned the car at 70k kms. Had a misfire later on which turned out to be a leaky index 2 injector on cylinder 6. 10 each or all 6 for 50. Index 9 Fuel Injector. Put into my car by BMW Sylvania at 50k kms. I changed it out at 80k kms for index 12 injectors when my cylinder 6 index 2 injector started leaking and causing misfires on that cylinder. In perfect working condition. 80 firm. BC BR coilovers for the e8x and e9x series. Used for around 20k kms. In good condition. The adjustable sway bar end links are still on my car until my brand new OEM sway bar end links comes in and be exchanged for the adjustable ones to come out and then be sold with the coilovers. 700 firm. SOLD. Last edited by SE7EN335; 11-12-2016 at 04:39 AM.. |
10-31-2016, 10:05 PM | #2 |
29
Rep 270
I will take below please:
1. 6 x 5L of Castrol Edge Fully Synthetic 5w40 2. Brand new transmission pan bolts and drain plug Pm'd contact
Sapphire Black M4 | iPE - Valvetronic exhaust | VRSF 3″ catless dp | Bootmod 3 Stage 2 | OEM LED alcantara steering wheel | OEM M4 GTS CF hood | Vorsteiner GT wing | M Performance CF splitter | Vorsteiner CF front lip | M Performance CF side skirt extension | 3D CF diffuser | OEM CF mirror cap | H&R lower spring | Rays Engineering TE37 Ultra Bronze 20x10F 20x11R
11-01-2016, 03:20 AM | #4 |
330
Rep 984
All Castrol Edge bottles have been sold. Pending pick up.
2 x Pentosin CHF 11S 1L have been sold. 4 remaining. 25 each. 2 x BMW OEM Coolant 1.5L have been sold. 4 remaining. 15 each. |
11-02-2016, 01:52 AM | #5 |
330
Rep 984
All Pentosin CHF 11S fluid and BMW OEM Coolant have been sold.
Mechatronic sealing sleeve and adaptor have been sold. Transmission pan bolts and drain plug have been sold. Motul Multi ATF will only sell 7L altogether for 150. Will not separately sell 1L bottles as you need 6-7L for an transmission service. |
11-11-2016, 12:08 AM | #9 |
Rep 35
BC BR Coilovers SOLD pending pickup!
2010 BMW 135i M-Sport BSM w/ Coral Red Leather Interior / MHD Stage 2+ / BMS DCI / ER CP / Tial BOV / BMWP Carbon Front Strut Brace / ST XTA Coilovers / VMR 19" V718 Wheels / DBA T2 Rotors / Ferodo DS2500 Pads / HEL Performance BBL / BMW M Performance Alcantara Steering wheel / BMWP SSK / BMWP Alcantara Shift+Brake Boot
