10-22-2016, 03:21 AM | #1 |
189
Rep 585
1M converts.. which wheel size?
For those who have done the 1M conversion on their E82s, whats the biggest wheel they have managed to fit (inc rolling the 1M arches too).
Fronts : I'm currently running Arc8s, 9.5j et22 with a yoko ad08r 255/35/18 tyre, clears ok with some liner mods (via heatgun). I tried a BBS 9.5j et 18 with a Cup2 265/35/18 and it just hits the oil cooler/inner side of the liners etc, on half/full lock. Rears : Arc8 10.5 et 27 with 285/30/18 - yoko BBS 10.5 et 22 with 295/30/18 - cup2 - even with rolled rear arches, this sticks out quite alot. I know the tyres are different in size, the cup2 sidewall is massive compared to the yoko tyre. Cup2 is also more squarer contact patch than the yoko. I have kept my 135i wheel hubs, and not opted for the e9x M3 ones, even on the rear, as the track is a touch wider by default. thanks
If its broke.. Mod it! if not, mod it anyway!
10-22-2016, 06:32 AM | #2 |
1Addict
3234
Rep 7,894
Something like 15mm outboard in rear with 135i hubs. So id go for 25-30 offset rear, with 27-30 more ideal if you want to put fat rubber back there.
10-22-2016, 03:23 PM | #3 |
463
Rep 476
Drives: e46 M3, e82v8 (s65 swapped)
we've turned rear hubs on leathe to e9x (non M) offset (new bearings + correct rotors), and now using square setup 18x9.5 et22 all around.
ps 275/35 tyres (hankook z214) |
dbronnik223.00 |
11-22-2016, 08:23 PM | #4 |
675
Rep 4,080
Rear hub conversion gets you to OEM 1M offsets
https://www.ecstuning.com/b-assemble...33416760058kt/ Otherwise assume you have to work with M2/M4 offsets. 10.5 would need et34 or higher to work in rear if you want to run beefy tires |
