10-01-2016, 01:45 PM | #1 |
128
Rep 1,144
E70 JL Audio Stealthbox SB-B-X5E70/10W3v3
If you are underwhelmed with the bass in your X5, then this should fix the issue. I had this in my E70 X5M with the enhanced premium audio system (aka Individual, or Dirac system). It integrates very well into the trunk under the floor, taking up effectively no useful space. The amount of bass is impressive due to the W3v3 driver specs and corner loading location in the trunk. I ran it with a 500W RF amp. I still have the amp if you are interested. I bought new from crutchfield in 2014. I was expecting to use it in my F85, but there is a secondary battery in the spot it's meant to go in, so I can't use it. This includes all the hardware needed to install. Shipping is not included in the price. It's pretty heavy so I'd estimate it will cost about $60 to ship UPS Ground CONUS. Model: SB-B-X5E70/10W3v3 http://www.jlaudio.com/product/54216.103634.2095.41496.1116712/BMW_X5_%28E70%29_%2707-%2713 Info from their site: The X5 artfully blends the dynamic attributes of a great road car with the utility and versatility of an SUV. What it doesn’t have is a real subwoofer system. The small woofers under the front seats can only do so much. Our Stealthbox® design team has come up with the perfect subwoofer solution for the X5. It installs under the cargo floor and wraps around the spare tire, taking up no cargo space and remaining completely invisible. Inside the Stealthbox®, a 10-inch JL Audio subwoofer driver pounds out controlled and powerful sub-bass that will completely transform your listening experience. The Hard Data: Contains one 10W3v3-2 subwoofer in a sealed enclosure. 500 watt power handling. Wired for 2 ohm mono. Black steel mesh woofer grille is included. Installs beneath the cargo area floor in the passenger-side rear corner of the spare tire well without impeding access to the spare tire. Installation requires removal of under-floor tool stowage compartment and necessitates relocation of the included tools. Will not fit X5’s with 3-row seating option. Manual: SBBX5E70_MAN.pdf Last edited by jml; 10-17-2016 at 05:29 PM.. |
10-02-2016, 10:03 AM | #3 |
128
Rep 1,144
Responded.
If anyone is curious, here are the install instructions for the Stealthbox. SBBX5E70_MAN (1).pdf |
10-02-2016, 12:14 PM | #4 |
12
Rep 106
PM Sent
Helix SDM125, Helix V-Eight DSP, Match, JL HD900/5, OEM L7 speakers, Morel SC 10 (in JL Stealth box)
Turbo Lag - Giving the NA guys just 1 extra second of false hope... |
10-08-2016, 05:35 PM | #6 |
686
Rep 1,002
I remember in the glory days when I was rocking a Tahoe Limited and had two 12" Kicker SB's with a Phosgate amp. That thing interrupted your breathing rhythm.
