09-03-2016, 09:42 AM | #2 |
21121
Rep 20,741
Drives: 2021 911 turbo
I doubt the NT01 285/35R19 would work in front.
I had the rear 275/35R19 PSS installed in front and it was a tight fit. There was very little clearance left with the fender liner with only partial steering angles (see picture below). The NT01 tread is quite squarer and wider than the PSS, so I seriously doubt an even taller and wider NT01 would fit without interference.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 09-03-2016 at 09:48 AM.. |
09-03-2016, 09:59 AM | #3 | |
256
Rep 928
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT |
09-03-2016, 01:19 PM | #5 | |
21121
Rep 20,741
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
mercedesc63256.00 |
09-04-2016, 07:14 AM | #7 | |
21121
Rep 20,741
From what I read, the RE71R is a pretty stout track tire and should wear less than an NT01 (200 tread-wear rating vs 100)... Otherwise, there is the Pilot Sport Cup 2 that you can have in either 255-275/35R19 or 265-285/35R19 (much more expensive), but are a fair bit pricier than the RE71R.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 09-04-2016 at 07:22 AM.. |
09-04-2016, 08:27 AM | #8 |
23
Rep 91
wear is worse on left side due to lcmt. but afraid camber plates will throw off my balance for street driving. they last 3-4 days now. and although there is tons left to improve I feel i'm pretty smooth and not overdriving the car.
09-04-2016, 10:22 AM | #9 | |
21121
Rep 20,741
The M4 does not need a huge amount of camber (as opposed to the E46 and E92). I run -2.5deg in front and I am able to wear down my track tires pretty evenly. I do need to swap them inside out mid-way though. So far I am not seeing any adverse wear on my street tires with the -2.5deg camber and the car feels much more stable and planted. Interestingly, my F82 wear rear tires way faster than fronts. The first of M3/4 to do so, I guess all that torque coming out of corners is a big contributor to that .
09-06-2016, 03:01 PM | #10 |
23
Rep 91
id love to run nt01 but it seems hard with these brakes. i love the re71r but lasting only 3 days is getting a little silly. what size are you running again canautom3?
09-06-2016, 03:06 PM | #11 |
3138
Rep 2,953
I think 285/30/19 is possible but not a 35 profile.
Check out this thread where a 305/30/19 was run in a square setup: http://f80.bimmerpost.com/forums/sho....php?t=1146898 |
09-06-2016, 03:23 PM | #12 | |
21121
Rep 20,741
I am surprised that the RE71R would wear that fast. They should last at least as long as the NT01. The reason I keep asking, is that if the problem is with your car/alignment, switching tires will likely not improve things much. Going with a stickier compound can even make things worse (more tire rollover due to the increased grip, hence more shoulder wear). Before I installed my camber plates, I wore down a pair of front NT01 to the cord on the outside shoulder in just 3~4 track days with still had over 60% of tread depth left on them on the rest of the width. I was pissed . I am running 275-305/35R18 NT01 on 18X10ET25-18X11ET44 Apex EC-7 wheels
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 09-06-2016 at 04:33 PM.. |
