08-14-2016, 02:19 PM | #1 |
594
Rep 562
Drives: BMW M2 2017
Z4M: Will these wheels fit? Click for pic + Spec
Will these fit my Z4 M Coupé?
Cades Shift Front 18x8 ET35 rear 18x9 ET40 /Filip
My cars: http://WWW.GARAGET.ORG/PHILLY
08-16-2016, 10:25 PM | #3 |
1821
Rep 5,337
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
08-17-2016, 12:01 PM | #4 |
52
Rep 617
08-17-2016, 01:23 PM | #5 |
1821
Rep 5,337
I'm not so sure that the rear will fit without a spacer, although I have seen someone run one of the front 8" wide rims in the rear in a pinch and it sort of fits. Regardless "those will fit fine" wouldn't be my first recommendation.
At the MINIMUM a 10mm spacer is required to push the track out to the same spec as factory in the rear. Depending on the tire(s) used there might be some rub on the inside without it. Heck when I run 275/35/18 Toyo Proxes on 18" x 9.5" et 26 wheels on the rear, it would rub the inside fender well ever so slightly on high-G corners. And that's only 2mm less inside clearance than STOCK based on offset calculations. I dunno. I'm not a wheels or tires expert. Those offset looks to be intended for a non-M E36/E46/E85/E86 fitment. I wouldn't run it without a 10-15mm spacer in the rear. But that's just me.
08-17-2016, 03:46 PM | #6 |
52
Rep 617
08-17-2016, 04:33 PM | #7 | |
1144
Rep 2,869
Drives: Anything
08-17-2016, 06:42 PM | #8 | |
52
Rep 617
Where's my head at today? Original Z4M rear wheels are 18x9 ET30. ET40 will have 10mm less clearance. OP, measure the inner clearance from suspension to wheel and tires, and see if the 10mm tuck will come in contact. If not, you're in the green. If it does, you need spacers. Also, I spoke to our Rep at TireRack and they have 18x9 ET40 offered for the Z4M and they guarantee no spacers required. Of course the 225 will not accommodate the 9" wide wheels. |
