08-09-2016, 10:08 AM | #1 |
268
Rep 485
6MT Shifting Effort Inconsistency, Looking for Feedback
Problem 1: Rarely, when shifting to reverse after a cold start, the shifter will get stuck somewhere between the final reverse position and the safety gate thing. The issue goes away after returning to neutral and trying again.
Problem 2: Up-shifting effort, in general, varies wildly. This is most prominent however on 2-3, and 3-4 shifts. When performing these shifts, I often feel an extra click or two of mechanical resistance/lugging in the gearbox that isn't always there. When this happens, it almost feels as if something is getting in the way of the final in-gear position and I have to push past it. Does anyone else experience these problems? Any ideas what either of these could be? |
08-09-2016, 10:23 AM | #3 |
321
Rep 451
08-09-2016, 10:40 AM | #4 |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Have you tried using the clutch?
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
8
RobbyMack738.50 SROC31702.00 Halewafa353.00 frankiebones5300.00 doberzus678.50 ando2002.00 Doctor///M1799.00 mdemon245.50 |
08-09-2016, 11:08 AM | #5 |
61
Rep 123
I'm getting out of an '08 335i 6MT with 125k mi and into an M4 (6MT). Since it was new, the tranny in the 335 occasionally will require a bit of muscle. More when cold than when warm. That really hasn't changed much since when it was new, and it's essentially the same now, with 125k mi. My point is that some of this is natural with almost any MT.
08-09-2016, 11:14 AM | #6 |
Part Time Firetruck Crash Barrier
789
Rep 1,563
Every once in a while the same thing you're noting with reverse happens to my first gear.
Usually if I just engage second gear and then throw back up to first it will go in smoothly. Its kind of weird but I've gotten used to it. I actually had the same problem I just mentioned in my 335 and then the synchro went and they had to warranty replace some tranny parts. . . Not to scare you or anything but that could be a similar issue.
m340ix Mineral Grey/Tacora Red |
08-09-2016, 11:36 AM | #7 | |
382
Rep 534
08-09-2016, 11:42 AM | #8 |
The limit of adhesion is my home.
1702
Rep 3,778
Maybe your clutch needs adjusting? I'd take it into the dealer and ask them. You shouldn't have to deal with crap like that. I personally have a 6MT and don't have those issues. While a weighted shifter might help the "feel" of it, you should not be having difficulty with the stock shifter to begin with.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
SakhirM410784.50 |
08-09-2016, 11:58 AM | #9 |
191
Rep 516
I have 4K miles on mine and haven't experienced anything out that has got my attention except for the shifter getting stuck and not going into reverse a handful of times.
08-09-2016, 04:56 PM | #10 |
368
Rep 1,175
Drives: 2015 SO/SO F80 & 135 M-Sport
Once in a while I have an extra "click" from third to fourth. Used to it with 13K on the clock. Happens maybe once per week.
///M3 SO/SO / MT / 19" Black Alloys / Executive Pkg. / Lighting Pkg. / Adaptive Suspension / Enhanced USB / HK / Full Front XPEL / 35 Tint / MODS: Custom painted engine cover and grill surrounds, Pedal Haus Kit, M-Performance Alcantara shifter/boot & e-brake boot, carbon e-brake handle, wrapped seat shells/rear headrests, M-Performance Spoiler with CRT Stripe.
08-09-2016, 07:13 PM | #11 |
Out in the middle of the sea
231
Rep 471
ive had this happen on a lot of different cars especially when the trans is cold still. Im no pro, but I believe its because reverse gears on manual cars dont generally have syncros. Its a cumbersome thing when the trans donesnt let you into reverse, but can easily be solved by letting the car roll a few inches, going back to neutral and trying the gear again.
sr/188.50 |
08-12-2016, 10:23 AM | #15 | ||
200
Rep 286
Current:
2020 M2 Comp (AW) 6MT Previous: 2018 Mini Cooper S (F56) (grey/black)6MT 2015 NC Miata club PRHT 6MT 2007 911 Carrera 2 (black/tan) 6MT 2017 Grand Sport (blue/white/red) 7MT 2015 BMW M4 (BSM/SS) 6MT 2011 C63 AMG (black/black) 7A |
08-14-2016, 09:04 AM | #17 | |
268
Rep 485
Anyway.... I'm starting to notice that these issues are happening mainly when the transmission is cold. I'll change change the transmission fluid and see if that helps. |
08-14-2016, 09:55 AM | #18 |
91
Rep 299
Drives: m3 2015
It seems to me that shifting ease or not depends on what type of driving you are doing. At speed the trans is perfect at lower speeds you can feel the spring assist in the trans but not a problem at all. If you think reverse is a problem you should try my 36 Ford not that requires attention
08-15-2016, 04:05 PM | #19 |
73
Rep 83
I've not noticed these issues with my 6MT. It does shift a little bit "stiffly" before the engine/drivetrain is warmed up, but that stiffness is pretty consistent through the gears. Once the engine/drivetrain is warm, I think it shifts quite well.
