BMW X5 and X6 Forum 2014-Current
Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > Vendors Classifieds
      07-28-2016, 02:36 PM   #1
chris @ eas
274
Drives: BMW
▀▄ eas | BMW Coding & Personalization - $95 "ALL YOU CAN EAT" Special!
european auto source is proud to be your #1 Southern California coding facility!
Whether its a simple Check Engine lamp or are looking for full retrofit coding - we are your one-stop facility for your programming needs.
Why should you choose eas as your SoCal coding facility?
- Over 10+ years experience in module coding
- Fully Equipped with Autologic Diagnostic Scanner/Programmer
- Autologic Optical Interface (OPS Diagnostic Head)
- Proper Voltage Stabilization maintained with Fronius ACCTIVA Professional Flash (70 Amp)
- Non-biased programming facility, with no fear of warranty rejection.
The Autologic diagnostic tool for BMW vehicles is without doubt the most comprehensive tool to be made available to independent BMW specialists. Autologic BMW is unique in offering full dealer-level fault code read and re-set, full component activation, electronic control unit procedures, clearing and setting of adaptation values, full coverage of (ECU) control unitscoding, full programming capability including engine control modules and transmission control modules, adjustment of engine idle, real-time reading of all dynamic data, procedure for engine and immobilizer alignment, procedure for trial substitution of control units and procedure for the fitting of BMW accessories.
The Autologic Optical Interface has been designed to program the CCC-A control units on BMW. Connecting directly to the fibre optic MOST bus, the Autologic Optical Interface is able to communicate with CCC-A, CCC-BO, CCC-ASK, CCC-ANT, ULF TCU and MASK ECUs. The Autologic Optical Interface significantly reduces the time to program these control units and further increases the reliability and recoverability of flash updating these control units.
Power Stabilization
Intelligent battery charging systems are very important given the technology of BMWs. We use the Fronius ACCTIVA Series with Active Inverter technology, the only all-round charger which Autologic recommends.
Detailed Explanation of features
When completed, a complete demonstration of all features are given so you are 100% familiar with your new options.
Why do you not perform remote coding?
A number of precautionary steps are taken in order to ensure your BMW is safe during the coding process, which cannot be verified remotely. Your pride and joy and its well-being is important to us!
Lighting
O Brighter Angel Eyes (50% brighter)
O EU-Spec “Dazzle Headlights” (LED Adaptive lighting only)
O Enable Brake Force Display (BFD)
O Door Handle LED on when in reverse
O Amber Corner Delete
O Adaptive LED Cornering as Fog lights
O Choose BFD Pulse Count (3/5 Flashes)
O Disable Angel Eyes
O Remove BulbCheck on Front Turn Signals
O Change Sport Interior Lighting from 64-100%
O Enable Taillight DRL
O Disable Headlight CELIS (eyebrow)
O Remove BulbCheck on Rear Turn Signals
O Remove BulbCheck on Reverse Lamps
O EU Rear Foglamps
O Reduce Automatic Headlight Sensitivity
O Turn Signal Flashes w/ Unlock (3 or 5)
O Turn Signal Flashes w/ Lock (3 or 5)
Exterior
O Close Windows with Comfort Access (CA)
O Fold Mirrors with Comfort Access (CA)
O Fold Mirrors with FOB (2-Step)
O Adjust Passenger Mirror Tilt in Reverse
O 1-Touch Window Up while Doors Open
O Pass mirror dips less when in reverse (decrease dip range)
O Fold Mirrors with door lock (AUTO)
O Windshield Wiper Return
O Disable Audible Chirp when locking
O Disable Auto-Locking of Doors once driving away
O Disable Headlight Washer Jets
O Disable Horn Honk when closing vehicle
O Disable Horn Honk Locking
O Amount of Sprays per Headlight Washing (2 or 3 pulses)
O Close Windows with FOB
Interior
O Remove Seatbelt Chime/Reminder
O Auto Start/Stop (remembers last option)
O Always Remember Air Recirc. on startup
O Remove Speed Correction Factor
O Disable Active Sound
O EasyEntry Seat adjustment (during unlock)
O Always Remember AC OFF on startup
O Start vehicle without brake pedal
O Digital Speedometer on BC Stalk
O Specify soft-touch blinker count (1-9)
O AC does not turn on when pressing AUTO
O Unlock door when engine is OFF
O Disable Welcome Sound (3 Gongs)
O Unlock all doors automatically upon vehicle shutdown
O Auto Start/Stop default to OFF
O Change Interior Gong Sound (RR)
Navigation/iDrive
O Enhanced Bluetooth (6NS)
O Allow Top Camera View at all speeds
O DVDinMotion
O Enable USB Video/Movie file import
O Bluetooth Pairing display at any speed
O Allow Side Camera View at all speeds
O Change NAV voice (British/US)
O Enable Video playback from USB
O Owner's Manual display at any speed
O Allow Side Camera View at user-defined speed
O Change DVD Region Code
O Enable Full Text in Office while Driving
O Change iDrive startup animation
O Disable Top Camera View at user-defined speed
O Add slider in iDrive for ambient light
O Turn off iDrive when door is opened
O Fuel Stop Sugg. in Route Guidance
O Disable iDrive Legal Disclaimer/Accept
O Disable Office Function Speed Lockout
O GPS Current Location to NAV menu
O Fuel Reserve Warning (9 liter to 6 liter)
O iDrive Map AutoZoom mode
O Disable Rear Camera Legal Disclaimer
O Efficient Dynamics Mode (6MT only)
O Enable Speech Input for Email & SMS
O Add/Remove TPMS Tire Temp/Pressure Data
O Disable Side Camera Legal Disclaimer
O Enable Route Preview
O Navi Trip Import/Export
O Increase Maximum Message Count (max 50)
O Create new Voice Email
O Change BT ringtone to personal tone
O Volume Level upon Vehicle Startup (25%, 50%, 75%)
O Advanced Real-Time Traffic Info
Phone:
You can reach us directly by calling 866.669.0705
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM to 2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x26
Email: mo@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
      08-02-2016, 02:50 PM   #2
chris @ eas
274
Drives: BMW
Coding slots available for this week!
      12-27-2016, 06:32 PM   #3
chris @ eas
274
Drives: BMW
Coding Slots available for immediate booking
PM for details and availability
      01-02-2017, 06:53 PM   #4
chris @ eas
274
Drives: BMW
Coding slots open and ready for immediate booking!
PM for details.
      01-03-2017, 06:58 PM   #5
chris @ eas
274
Drives: BMW
Coding slots available for immediate booking,
PM for details!
      01-11-2017, 06:54 PM   #6
chris @ eas
274
Drives: BMW
Make sure you stop by this saturday for our Dyno / Coding event!
      02-21-2017, 01:37 PM   #7
chris @ eas
274
Drives: BMW
Coding slots available for immediate booking!
PM for details!
      03-20-2017, 06:50 PM   #8
chris @ eas
274
Drives: BMW
Coding slots are open and available for immediate booking!
      03-24-2017, 05:57 PM   #9
chris @ eas
274
Drives: BMW
Coding slots open and available for immediate booking!
      03-27-2017, 06:57 PM   #10
chris @ eas
274
Drives: BMW
PM for details!
      03-28-2017, 06:12 PM   #11
chris @ eas
274
Drives: BMW
PM to book your appointment!
      03-30-2017, 06:59 PM   #12
chris @ eas
274
Drives: BMW
All PM's replied to!
Coding slots still available.
PM to schedule!
      04-03-2017, 11:33 AM   #13
chris @ eas
274
Drives: BMW
Coding Slots available for immediate booking!
PM to get your car coded today!
      04-04-2017, 04:01 PM   #14
chris @ eas
274
Drives: BMW
Coding slot still available for this week!
      04-06-2017, 06:55 PM   #15
chris @ eas
274
Drives: BMW
PM to get your car coded!
      04-07-2017, 06:08 PM   #16
chris @ eas
274
Drives: BMW
PM today to schedule your coding appointment!
      04-10-2017, 05:35 PM   #17
chris @ eas
274
Drives: BMW
All PM's Replied to!
PM today to get your vehicle coded!
      04-12-2017, 06:48 PM   #18
chris @ eas
274
Drives: BMW
Coding slots available!
PM to schedule an appointment!
      04-14-2017, 06:05 PM   #19
chris @ eas
274
Drives: BMW
PM to book your coding appointment today!
      04-17-2017, 05:59 PM   #20
chris @ eas
274
Drives: BMW
PM to reserve your slot today!
      04-19-2017, 06:00 PM   #21
chris @ eas
274
Drives: BMW
Coding slots still available for immediate booking!
      04-24-2017, 06:27 PM   #22
chris @ eas
274
Drives: BMW
xbimmers
