07-03-2016, 09:42 AM | #1 |
Driven Crazy
190
Rep 505
Will 225/45/18, 245/45/18 rub?
I picked up a base (and I mean base - no frills 33k mi 6m) 128i a few weeks ago.
I took it to a DE a few weeks ago and ran the 16" R compounds that were on my E36 M3, and then used to autox my M Roadster. Needless to say they are old and one is now corded. I will probably only run two or three more DEs and maybe two autox this year with the 1. My buddy offered me the low mileage tires from his 350Z. I can pick up a set of 18x8 et 47 rims from craigslist, or a set ot 18x8.5 et 48. The question is will the taller tire 26" in front 26.7 in rear vs. 25" rub. I know the speedometer will be off, I know I will induce more understeer than if I used a square setup, and I know they wont be as fast as R compounds, but will be faster then the brand new run flats the PO put on the car shortly before his wife decided to sell it. Thanks Last edited by Tommm; 07-04-2016 at 08:18 PM.. |
07-10-2016, 05:18 PM | #3 |
545
Rep 1,233
Honestly with non-m-sport (you didn't mention what options/suspension on your car, assuming non sport) you might be okay for now but you're taking away clearance in the event you update your suspension...
realizing you're getting cheap tires...may be worth looking around for a used set of the correct size rather than your friend's tires. I just spent a lot of time researching and chose a fitment that I thought would be no problem based on results of others, and sure enough it rubs on one side in the rear (so far). Didn't want to mess with rolling fenders etc, but these cars are pretty restricted in fitment terms. |
07-10-2016, 05:27 PM | #4 |
European Editor
10589
Rep 22,992
Get GOOD tires!
I bet Gary@TireRack would know.
The only thing you should do is get the best tires you can afford. Especially if you are replacing the RFT's... you really need a top tier tire like the Michelin PSS. Some of the cheap-er (non-RFT)tires can really our cars handle squirrelly. I am not sure about those wheel sizes and tires. I bet IF you go onto TireRack's website you can find the answer when you plug in your car's build specs Dackel
07-12-2016, 10:21 AM | #5 |
2042
Rep 25,989
You're going to want to use a 40 profile in the front and a 35 profile in the rear. A tire that tall in the front, especially with the 8.5 ET48, will likely contact your suspension on the inside.
07-15-2016, 06:47 PM | #6 | |||
Driven Crazy
190
Rep 505
Thanks to all who helped.
The car has zero performance options. The gal I bought it from won it in a raffle. Butt warmers and metallic paint are it. But with 32k miles on it, garaged every winter under a cover, etc. I figured with my M roadster, and half a 944 that we just track this would be a nice daily driver that I can track and autocross a few times a year. the stock diameter is 25" and the ones I can get for nothing are 26" in the front and 26.7 in the rear. Because I am not sure the Z tires wont rub, I am picking up some 17x8 style 112s for winter or track tires, and have 16x7.5 with the corded R compound from the E36 M3 i sold a few years ago,so my I should be able to find good tires from my spec boxster friends in a month or so. Quote:
I know I should get the best tire i can afford, but I don't think a stock no option (metallic paint and butt warmers are the only options) 128i can get everything out of a set of pilot sports (my M roadster doesn't). maybe 90% out of a set of hoosiers, but I don't want to spend $ on tires for the track this season, hence the used tires. Next season I will probably get a new set of R compounds (I don't want to store them over the winter in my garage). Quote:
If anyone has tried the taller tire I would appreciate hearing. Thanks Tom |
07-23-2016, 10:34 AM | #7 |
87
Rep 268
I had some rubbing issues with 245/35-19 on 8 x 19" ET47 (BMW) wheels in back. I don't think 245/30 would have cleared either. The rubbing was on the outer edges of the tires. I also had rubbing issues in the front with the same wheels and 225/35-19 in front. Problem solved with the slightly greater offset of E82 wheels and 215/40-18 and 245/35-18 tires.
I'd like to be able to use 225/40-18 and 255/35-18 tires to have more choices for tires, but I don't know if they will also produce clearance issues. Edit: Just read the post from the sticky notes which says the 225 and 255 sizes above will fit a stock suspension without rubbing. I wonder if that is still true if the suspension has been updated to M3 suspension arms (front and rear)? Last edited by MAMSport; 07-23-2016 at 10:41 AM.. Reason: read post in sticky notes |
