06-29-2016, 02:56 PM | #1 |
14
Rep 85
Exhaust trick?
Anyone ever tried this little trick that the M2's do on our 135i's with DCT to see if the exhaust burbles get louder? Would love the cold start sound to be there all the time.
http://f87.bimmerpost.com/forums/sho...1277527&page=2 "Perhaps this is the same result as what we were told on our M Tour #2. That if you first press the ignition, but not crank over the engine, then put it in Sports+ mode, then fire up the engine, you we get the "loud" mode at startup. We were also informed that there is a method to keep the exhaust flap permanently open. With the engine at regular operating temp, put the car in Sports+, then go underneath the car and pull the electrical connector to the exhaust valve which controls the flap. This will lock the flap in the open position." Been driving my e30 vert with summer weather so haven't had a chance to test it out. I will next time I get it out. Just curious if we have some hidden coding in there. Andrew |
06-30-2016, 05:43 AM | #2 |
1302
Rep 2,093
Drives: '11 135i M Sport
I don't think so? Considering the software is a lot different from the M2 to our 135i.
I'll have to test it out in few mins when I leave for work and I will report back.
06-30-2016, 05:50 AM | #3 |
European Editor
10594
Rep 22,992
135i's have a vacuum operated exhaust servo(hence the golf T mod). M2/M4's have an electrical servo.
06-30-2016, 01:35 PM | #4 | |
52
Rep 374
New Car: 2019 Porsche 718 Cayman GTS | Stock for now Old Car: 2013 BMW 128i | 6MT | BMW Performance Grills | CDV Delete | SSK | Performance Exhaust | M3 RSFB | TCKR DA |
06-30-2016, 05:42 PM | #5 | |
Rep 24
06-30-2016, 06:06 PM | #6 | |
1Addict
3237
Rep 7,897
1. Golf Tee Mod 2. Aftermarket exhaust parts 3. Force the wastegates full open when below like 5% throttle (JB4/MHD). Edit: saw you have the Dinan unit, which unless I'm mistaken doesn't even have a flapper.
07-01-2016, 03:43 AM | #8 |
European Editor
10594
Rep 22,992
You basically disconnect the vacuum line that goes to the exhaust flapper valve and stuff a golf tee into the hose end.
Golf Tee Mod... http://www.1addicts.com/forums/showthread.php?t=213042 http://www.1addicts.com/forums/showthread.php?t=594188 http://www.1addicts.com/forums/showthread.php?t=214066 Negative effects of Golf Tee Mod? http://www.1addicts.com/forums/showthread.php?t=415845 Personally, IF you want a louder exhaust the BEST thing you can do is to get a PE for the 135i. I messed around with installing N55 mids only to go back to stock and installed a PE. I should have just done that. The PE is the BEST sounding awesomeness exhaust I have had on any car. It really makes the car so much nicer to drive. I LOVE it! Here is what the OE vx PE exhaust looks like. The PE has chrome tips(vs the OE's black tips) and the PE does not have this vacuum operated servo.
07-01-2016, 08:06 AM | #9 |
211
Rep 893
PE is just cat-back?
2011 135i MSport 6MT AW/black, 72Kmiles, bone stock, moneymoneymoneymoneymoneymoneymoneymoneymoneymoney I LOVE THIS CAR
07-06-2016, 07:45 AM | #10 | |
Former Opel GT Pilot
327
Rep 771
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
07-06-2016, 12:25 PM | #12 |
44004
Rep 7,226
The PE does not have have a flap in one of the exhausts that opens and closes and makes the exhaust sound louder (flap open) and quieter (flap closed) like the standard muffler. Both of the exhausts in the PE are always open and you get maximum volume all the time.
07-06-2016, 12:35 PM | #13 | |
327
Rep 771
07-06-2016, 12:39 PM | #14 |
44004
Rep 7,226
Good question. My guess would be to keep it quieter at times, and then be able to open her up and really hear it when you step on it? Personally, I want to hear it most of the time.
07-06-2016, 12:49 PM | #15 | |
327
Rep 771
I have read through the all the posts that Dackelone referenced above, and I found some additional conflicting information that you might be able to clear up for me. The very common opinion seems to be that the golf tee mod keeps both outlets open ABOVE 3,000 RPM for improved sound. However, there is a link to a YouTube video that shows that the flapper opens up immediately after the engine warms up. The guy in the video is holding a piece of cardboard up against the outlets one at a time. Both are clearly open at warm idle. This begs the question...Why do the mod if both are open from the point the car warms up anyway? Thanks for helping me understand.
07-06-2016, 01:12 PM | #16 | |
European Editor
10594
Rep 22,992
On the PE there is a place/fitting where the car's vacuum line slides onto - so there is no (vacuum)leak. The reason why BMW(and others) use a flapper valve is there are some very tough noise standards in Switzerland(and other countries). I've actually seen Blitzers(Photo radar) in Switzerland that will blitz you for your exhaust being too loud! lol
07-06-2016, 02:05 PM | #18 |
327
Rep 771
Ok. I am finally sold. I will try this mod very soon. Thanks guys!
07-06-2016, 03:52 PM | #19 |
211
Rep 893
instead disconnect the electrics at the actuator (behind the trunk liner along the side at the left), no need to get that suit dirty
07-06-2016, 04:02 PM | #20 |
211
Rep 893
I have a somewhat related question. My flap is non-operational, the electrics are disconnected at the actuator (solenoid that opens/closes the vacuum line to the flap) . But when I start the car up cold,, I clearly have a more throaty exhaust note at idle for the first 15-20 seconds... and then it quiets down a bit. Is there some cold-start emissions thing causing this?
07-06-2016, 04:26 PM | #21 | |
327
Rep 771
07-06-2016, 05:04 PM | #22 | |
44004
Rep 7,226
