06-28-2016, 10:15 PM | #1 |
40
Rep 167
When in R how to set Rear camera as default
When I select Reverse gear I want Rear camera to activate first not Bird's View as I have it now. How do I make that setting? As of now when in R default is Bird's view camera instead of Rear view camera. Thanks in advance .
06-29-2016, 12:17 AM | #2 |
19
Rep 193
When I am in R reverse camera is default and I actually want birds eye to be in default.
Mini R56 JCW 2013
Porsche 991 Carrera S 2015 BMW F15 X5 xdrive30d 2016 BMW E92 335i 2008 (SOLD) |
06-29-2016, 11:39 AM | #3 |
Self-Deprecating Narcissist
7266
Rep 6,561
not possible. i would like the same.
06-29-2016, 12:06 PM | #5 |
3240
Rep 5,066
From my experience Bird's eye view aka surround view only comes on default when you move the gear to reverse and you are very close to an object. I haven't tested how close you need to be though.
Otherwise in reverse, it is rear view only.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
07-03-2016, 03:21 AM | #6 |
2374
Rep 8,364
The vehicle will remember your preferred default. You can toggle viewers by pressing idrive controller down into the floor. Then, next time you put car in "R," it will be on last setting.
With PMA modules, you additionally have option for Auto-PDC to enable when driving slowly close to other object. |
07-03-2016, 07:04 AM | #7 | |
3240
Rep 5,066
07-03-2016, 07:13 AM | #8 |
2374
Rep 8,364
I am 100% sure that is the way it works in my cars. I like looking over my shoulder for rear view when backing up while utilizing a combination of side mirrors plus top view for parallel parking as well as pulling into spaces to visualize curbs and lane markers. Mine maintain the view I want.
07-03-2016, 08:40 AM | #9 | |
3240
Rep 5,066
07-07-2016, 03:59 PM | #10 | |
219
Rep 480
07-07-2016, 04:06 PM | #11 | |
2374
Rep 8,364
07-07-2016, 05:50 PM | #12 |
3240
Rep 5,066
So you are saying if a car is equipped with ACC Stop & Go option then it allows the car to remember the last reverse camera view? Maybe that should have been clarified, because a car not equipped with 5AT does not allow that.
07-07-2016, 05:53 PM | #13 | |
2374
Rep 8,364
EDIT: Just to be clear, my cars are coded. However, I did not code anything special for this function to work as desired. Further, ACC has nothing to do with this function working. Last edited by Almaretto; 07-07-2016 at 07:40 PM.. |
07-07-2016, 08:03 PM | #14 | ||
3240
Rep 5,066
07-20-2016, 02:49 AM | #15 | |
2374
Rep 8,364
I am not sure if it because my F15 has PMA_PDC module which allows for Auto-PDC when slowly approaching objects from any side or the fact that I am rather familiar with both vehicles controls so much that I have, slightly different, though very fluid no-look synaptic (muscle memory) button changes. Nevertheless, I am no longer completely convinced. After briefly testing, I thought I may be 100% wrong. Then, I checked the owner's manual and now the only thing of which I am sure is my confusion. I retested, and the following were my initial findings:
I am not sure yet the reason for the differences in the tested chassis behavior and conflicting manual information. Other than HU_NBT, they use different relevant ECU modules; but, I will further test and, if need be, compare CAFD's to see if I can replicate desired behavior. Last edited by Almaretto; 07-20-2016 at 02:55 AM.. |
07-20-2016, 07:00 AM | #16 |
16
Rep 62
My car defaults to the rear camera because I have it selected in the menu. If I put the car in reverse, the rear camera comes on and a single downward press of the iDrive controller will deselect the rear view camera to get bird's eye view. Another press of the iDrive controller reselects the rear view camera and I get that back. Activating the bird's eye while the gear selector is in "D" is a different procedure.
- Patrick |
07-20-2016, 07:53 AM | #17 | |
3240
Rep 5,066
07-20-2016, 07:56 AM | #18 | |
3240
Rep 5,066
07-20-2016, 08:24 AM | #19 | |
16
Rep 62
- Patrick |
07-20-2016, 09:35 AM | #20 | |
3240
Rep 5,066
Try this.. do your setting as mentioned above and set it as Bird's eye view aka surround view. Then shut off the car turn it back on and put it in reverse and let me know if you are in bird's eye view or the standard rear view. ( note make sure there isn't anything obstructing your PDC while doing this )
07-20-2016, 12:34 PM | #21 | |
2374
Rep 8,364
07-20-2016, 12:46 PM | #22 | |
16
Rep 62
- Patrick |
