06-24-2016, 10:45 PM | #1 |
M3AT LOVER
322
Rep 1,853
Thinkware F770 Dashcam Review
I ordered the brand new Thinkware F770 from blackboxmycar.com. I was in town so I picked it up in person at blackboxmycar's office in Richmond, BC, Canada. The customer service has been top notch. Justin was always quick to answer all my questions (and I had a lot of questions). I ordered the F770/Cellink B pre-order bundle. It comes with a 64GB SD card, hard-wire kit, a circuit tester, and installation accessories, and a couple add-a-fuses. I also ordered with the rear camera.
At their office, I was able to see F750 andF770 side by side. The F770 is noticeably smaller than the old model. The new model is slimmer and more streamlined. Gone is the stuck-out silver cylinder-shaped lens housing. The lens on the F770 is part of the unit's body. There is also a compartment on the side of the body for better cable management. The windshield attachment is now a thin solid piece of plastic. So the dashcam will be much closer to the windshield and appears even smaller than the old F750. I installed it yesterday with the rear camera. On my BMW M3, fuse 155 was recommended on Blackboxmycar's YouTube video for F82 M4, for some reason, fuse 155 has no power for me. I didn't test it before so I don't know if it was like that or I did something wrong to the car. I ended up using fuse 159 for ACC. The add-a-fuse also came loose, so I had to repair it. But all is working after a couple hours of trial and error. Also thanks to Justin @ Blackboxmycar for extending my hard-wire cable so it is long enough for my car (fuse box in the trunk). Some random notes:
[EDIT: Added pictures.] ^ | | blackboxmycar.com will be sending me new right-angle cables to replace the straight ones I have. My hard-wire power cable already has a right-angle connector. New orders from blackboxmycar.com will include right-angle cables (power and USB cable if you order with the rear camera) so the flap can be closed. [EDIT] Pictures of the final right-angle USB cable: F770 footage from blackboxmycar.com's youtube channel.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
06-25-2016, 01:46 AM | #3 |
184
Rep 760
Can you live view the camera and have it still record like blackvue or is it still the same as the f750?
14 Audi S4 (sold)
16 BMW M3 (sold) 16 VW Golf GTI (sold) 20 Tesla Model 3 23 Audi R8 (on order, never came ) |
06-25-2016, 03:14 AM | #4 |
M3AT LOVER
322
Rep 1,853
When you start live view, it stops recording. I don't think it is a big deal as you see what the cameras see as you drive.
06-25-2016, 07:04 AM | #5 |
3462
Rep 3,996
Nice review. Any installed pics?
I was actually thinking about the F770 over the Blackvue, but I am still leaning towards the Blackvue because of it's smaller, and better looking case.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
06-25-2016, 01:53 PM | #6 |
M3AT LOVER
322
Rep 1,853
I can take some pictures later. I actually think the Blackview is quite large. It is thicker and longer. It doesn't hug the windshield like the F770 does.
06-26-2016, 12:23 AM | #7 |
Rep 18
How's the rear cam? Is it sharp? I have a F750 and the front cam is great but the rear cam is a bit blurry. It's not sharp for objects 6ft and farther. I may have a defective rear cam that is out of focus. r it may be due to my tint. If you can post your rear cam footage, it'll be greatly appreciated.
06-26-2016, 01:22 AM | #9 | |
M3AT LOVER
322
Rep 1,853
06-26-2016, 08:26 AM | #10 | |
3462
Rep 3,996
I actually have my V1 mounted in the same place in my X5.
06-28-2016, 01:02 PM | #11 |
913
Rep 1,427
How's the view from the front cam in that installed place? Got any screen grabs from some live shots? If I got one of these I would be mounting it up to the right of the mirror too.
07-03-2016, 08:03 AM | #13 |
131
Rep 267
Thanks for this post. I am about to buy the same setup from Blackboxmycar, so I appreciate seeing the success you've had with it. I just have a couple questions for those guys to make sure I'm ordering everything I need for the install. I appreciate the tip on the extra-long wiring and the right-angle USB cable.
08-08-2016, 12:03 PM | #14 |
144
Rep 125
Thanks for the writeup and photos. One of the rare threads with hands on experiences with the F770. I just ordered mine today for my F30 as a last-minute change of mind from a Blackvue 650S as the video quality should be better overall, and night samples look damn impressive.
This will be my first ever installation of a dashcam, so maybe you can help with a few questions: 1. so the 128GB cards are confirmed to work, right? 2. do I understand right that the provided hardwire kit is not long enough for BMW's battery in trunk? should I already get some extension wire? 3. assuming the fuses are the same between F80 and F30, which type of add-a-fuse should I get? 4. can you share any pictures of wiring in the back? any installation tips? thanks in advance! |
08-08-2016, 10:05 PM | #15 |
M3AT LOVER
322
Rep 1,853
Hey GoranBonn. I am using a Samsung Evo+ 128GB microSD card and it has been working fine. Another option is Lexar 633x 128GB microSD card. The hardwiring kit is not long enough because our cars' fuse box is in the trunk. I used the small version of the add-a-fuse. The hardwiring kit also has an in-line fuse. I will have to go to the garage to take some pictures of the trunk later.
BTW, I just installed the new Thinkware F50 to my Audi A3. It is a single-channel dash cam, but it also have voice prompt. Only $129.
08-14-2016, 04:00 PM | #17 |
131
Rep 267
Thanks again for your helpful post. I just installed the same setup and also had to use fuse 159 instead of 155. You saved me some trouble shooting time! I routed the USB cable around the driver's side since the rear camera's USB port is on the driver's side when oriented properly.
09-14-2016, 02:15 PM | #18 |
Rep 2
Thank you for this useful post Sir Loin.
I am a driving instructor in the UK and have just ordered this camera and will be having it fitted professionally on the 22nd June. I am interested in whether it is worth me buying a Samsung Evo+ 128GB microSD card or two. Chameleon, the UK distributors for this cam say that they have tried to get 128Gb cards to work due to customers saying this is possible but have failed to get them to work. They are assuming that people believe they are working when the device is actually only recording 64Gb to the 128Gb cards. Can you confirm for me that your Samsung card is taking around 8 hours of data when using both the front and rear cams? And do you believe that if I tried and it failed I would not be at risk of damaging the cam itself? Mine has come with a 32Gb card so I will either be buying at least two 64Gb cards but would much prefer to get one or two 128Gb cards instead. |
09-15-2016, 12:32 AM | #19 |
M3AT LOVER
322
Rep 1,853
I am using a Samsung Evo+ 128GB card. I bought it from Amazon in the US. It works and I can use the whole card.
Remember, nowadays storage device companies advertise storage devices in MiB instead of the proper Megabyte unit, so you don't actually get the full 128MB that you think you are getting. On top of that, Thinkware's dashcam setup partitions the storage space into multiple areas: continuous recording, incident recording (sudden motion while driving), parking recording (motion detection), parking incident recording (loud sounds and vibrations), manual recording. So you don't actually get to use the whole card for just continuous recording while you drive. This is actually a good thing. I bought the Samsung EVO+ 128GB card based on blackboxmycar.com's recommendation. There is another person on dashcamtalk forum just posted that he tested with a 200GB card and it works for him. As long as you buy from a reputable retailer, you should be fine. If you are in doubt, the other option is lexar 633x 128GB card. It is a bit more expensive and it also works. With the large card, I chose the partition option C so I get a larger partition for parking recording. Otherwise if you park for a few hours on a busy street, you will run out of space and your latest motion detection videos will have overwrite the older recording.
12-05-2016, 09:26 PM | #22 |
279
Rep 592
Bought mine from Blackboxmycar.com as well. Their customer service is top notched. Justin is very helpful. I wanted to upgrade from my X330 without the LCD. I just completed the install on my f15. However I noticed these weird internal noises (besides the ones in my head). It actually sounds like there's a short circuit inside the unit. I emailed Justin so I'm waiting to hear back from him tomorrow. I'm keeping the unit unplug for now until I hear back from the experts.
