BMW X5 and X6 Forum 2014-Current
      06-19-2016, 11:37 PM   #1
es1
40
Drives: 2023 X5
center armrest creaks
Every time I lean on the center armrest it creaks. Any suggestion on how to (and what to use) to lubricate hinges? Or any other suggestion. Thanks.
How do you atke it apart? They design beautiful cars but they just cannot make their plastic without noise.
      06-20-2016, 02:25 AM   #2
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Had this issue when the car was new (three years ago). Dealer actually fixed it as it was a common problem with many X5s. Sorry don't know what they actually did.
      06-20-2016, 03:05 PM   #3
double_j
86
Drives: 2008 JB/B E90 M3
Creaks like this aren't necessarily caused by a lack of lubrication in the hinge. It's more likely due to the plastic flexing. Look for where the armrest is flexing when you lean on it and see if you can use padded tape or pieces of felt to close those gaps.
      06-20-2016, 05:54 PM   #4
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
Yup, there is a thread somewhere here where they fixed the problem with small circular felt tapes they bought from Home Depot and placed it where the armrest top makes contact.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
      06-20-2016, 09:06 PM   #5
es1
40
Drives: 2023 X5
thanks guys
Thanks. Will need to locate that link with he fix as it is rather sad.
      06-21-2016, 09:17 AM   #6
stewy604
stewy604's Avatar
290
Drives: 2014 BMW X5 xDrive 35d M Sport
I had mine replaced under warranty...probably overkill, but I wasn't about to complain when they approved it.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey
2007 Suzuki GSX-R 750
      06-21-2016, 10:31 AM   #7
es1
40
Drives: 2023 X5
will see what they say on friday
I will go to dealer on Friday for oil change and will report this issue as well so let see what they say.
      06-21-2016, 09:52 PM   #8
asad
United Kingdom
Drives: 2015 X5 (F15) s25d
I've had this issue since buying my car and I forget every time I take it to a dealer, didn't realise it was a common issue. Due for a check up soon before I hit 50k miles, hopefully they can fix it.
      06-22-2016, 09:45 AM   #9
SpeedN8
Slower traffic keep right.
SpeedN8's Avatar
Drives: '14 X5 35d & '18 M4 Coupe ZCP
Same thing here. I told my dealer right after purchasing and they put some grease in the hinge. That worked for like a week. I've also tried felt tape. It's so annoying. Might not annoy most people but the smallest things bother me sometimes. :/
Current: 2022 Tesla Model Y Performance (my daily driver) - 2014 X5 35d M-Sport in Carbon Black Metallic (for towing) - 2018 M4 ZCP (track fun) - 2006 Z4 M Roadster (topless fun)
Past: 2021 Tesla Model Y Long Range - 2011 X5 50i Sport - 2006 750Li Sport - 2003 M3 Convertible - 2001 X5 4.4i Sport - 1999 Z3 Roadster 2.8
      06-22-2016, 11:08 AM   #10
wifesbimmer
158
Drives: '20 X5 M50i, E92 M3, '16 F150
I get annoyed by the smallest things in the world when it comes to vehicles. I think it is an illness quite frankly. That center armrest creaking sound has always been a problem in 60% of BMW's I have purchased. It creaks in my M3 and X5. I have just learned to ignore the sound. I have not tried the plastic gel type bumpers designed for drawers and cupboard doors. I have heard that they are the solution for the noise.
      06-22-2016, 02:03 PM   #11
BXdriver
Four stripes vehicle commander
BXdriver's Avatar
Norway
159
Drives: 21 BMW X5 45e
Sounds
Hi there,
Another one here - same issue from the beginning.
In fact also from my seat - the plastics surrounding the buttons for electric seat adjustment. Somewhere there.
Generally, I get mad and frustrated over even the smallest quirking sounds in cars, but in these cases - the sound
only comes when I move myself in the seat or support my arm hard on the armrest.
I tried to spray some silicone spray around/down the armrest plastic parts but to no help.
So...I have gotten used to these sounds and can live with them.
Best
Bent
      06-22-2016, 02:10 PM   #12
wifesbimmer
158
Originally Posted by BXdriver View Post
Hi there,
Best
Bent
If you are getting sounds when adjusting yourself in the seat, that should be looked after at the dealer. What kind of seats do you have?
      06-22-2016, 02:14 PM   #13
teodorjelev
Bulgaria
585
Drives: Mercedes AMG GT 53 4-door
I had the same problem with me, I took the car in the workshop and there fixed!
Let's knock on wood no longer is a problem!
      06-22-2016, 02:38 PM   #14
TallTrees
TallTrees's Avatar
148
Drives: 2014 X5 35d M Sport
I used these rubber door stops with success.
http://f15.bimmerpost.com/forums/sho...2&postcount=14
      06-22-2016, 03:17 PM   #15
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
Drives: Audi BMW Ferrari LR MB
if you install them on the door side they will be less noticeable. also a 3/8" should work fine, 1/2" may be too thick and cause cracking of latches or something that BMW may lean on for warranty denial. (just a thought)
      06-22-2016, 04:01 PM   #16
teodorjelev
Bulgaria
585
When BMW always something somewhere rattle!
      06-22-2016, 04:51 PM   #17
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
Mine creak as well, so I bought these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. I'll report back once I install them.
2014 X5 50i X-Line // Mineral White
      06-22-2016, 08:03 PM   #18
iconoclast
iconoclast's Avatar
7266
i used to think it was because of the firm suspensions but now you have this issues on some with the base squishy watered down suspensions.
      06-22-2016, 08:10 PM   #19
Taran.J
Taran.J's Avatar
Drives: BMW, LEX, MBZ, RAM, TESLA
I showed my tech at my first service and he said there isn't much he can do but grease it. Worked for a month. I'm going to have to show him this thread thanks fellas
      06-22-2016, 10:49 PM   #20
coolidge
56
Drives: X5 xDrive 35i
Having never owned a BMW before the first time I saw that center console I was like wtf that looks like a, well ah um well you know. Its still a bit odd to look at, cover that thing in shag carpet and your talking awkward!
As for the creaking I'm always looking for a reason to browse McMasterCarr website.
      06-23-2016, 10:43 AM   #21
es1
40
Drives: 2023 X5
Thanks Talltress. Will try that if dealer cannot fix it tomorrow.
      06-28-2016, 06:40 PM   #22
Kavir
Drives: 2014 X5
Mine used to creak horribly.
My dealer applied strips of felt to the underside of the armrest door which reduced it but it was still happening often enough to annoy me.
After a second visit to them they applied felt to the latch (the base of the latch that enters the hole to lock the armrest) and that completely resolved the issue for me.
xbimmers
