06-17-2016, 10:48 AM | #1 |
361
Rep 727
Power steering loss help!!
I need ideas. I have an 08 128 and my power steering went out. Fluid is at par and there's no whining but it's ran by servotronic right? I don't really know a lot about power steering anyway cause I've never had a problem with any car and this is my first bmw. I wanna figure out if there's any hacks I can try or if it's gonna cost me a months pay to fix. Thanks in advance
06-17-2016, 01:57 PM | #4 |
130
Rep 351
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
07-06-2016, 11:45 AM | #8 |
32
Rep 107
Maybe something is up with the belt/pulleys. I remember my '35 made a loud squeaking noise, when I sprayed water on the serpentine belt it stopped. Bought new belt, proceeded to replace it; turns out my power steering pulley was completely cracked and missing a good chunk too. I would feel a looseness when turning, after new belt and replacing the pulley everything was golden.
Also, if you know anyone who has a service scanner, that plugs in to the OBD port you could check the issue. If your power steering is completely out, the system should throw out a fault code. Lastly, the obvious solution would be to get in touch with BMW service (though they're all crooks as well as amateur mechanics /s). |
07-06-2016, 11:47 AM | #9 |
Former Opel GT Pilot
327
Rep 771
I think you need to look at these fuses... 5, 49, 75... if the power steering is the little drawing of the steering wheel on the chart.
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
07-06-2016, 05:23 PM | #10 | |
361
Rep 727
07-06-2016, 05:26 PM | #11 |
361
Rep 727
Tried that first mine only calls for 49 & 75. 75 was the only one in there and it was fine. Tried both in and still nothing. Do you guys know anything about rack and pinion could that be it?
07-07-2016, 03:00 PM | #13 |
39
Rep 456
I don't think there are any electronics in power steering in an 08 128i. The pump is driven by the engine belt. If there is no power steering I would check the belt/pulley followed by the fluid. If those are fine, then I would think your pump has failed.
07-07-2016, 04:23 PM | #14 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
Those listed fuses are for vehicles equipped with active steering only.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
07-08-2016, 09:23 AM | #16 |
BMW Master Tech
587
Rep 850
How many miles do you have? Is the problem intermittent or constant? If you lost the belt, you would loose the alternator as well, so other notifications would pop up in the cluster.
135is #502 of 586
07-11-2016, 08:56 AM | #20 | |
39
Rep 456
07-11-2016, 09:49 AM | #21 |
BMW Master Tech
587
Rep 850
It's right under the alternator. Should take an hour and a half to replace. Maybe two and a half max.
135is #502 of 586
Tags |
power steering, rack, servotronic, steering |
