      06-16-2016, 04:40 AM   #1
chrisN
chrisN's Avatar
Australia
30
Drives: bmw 125i coupe
2010 125i  [8.66]
Full car electrical failure; trying to diagnose
Hi guys I was wondering if anybody had experienced the following, and/or had a solution.
Car will run perfectly for days. I'll drive out for a dinner. I come back after an hour and the car won't unlock. Key also won't slot into position, no welcome lights, and car does not start. Absolutely zero power.
I'll come back in another hour, and the car works perfectly again. Time and date on the car will have changed though. This happens on and off for the last few weeks.
Im trying to diagnose the problem; I'm reluctant to consider it a battery issue only, but I could be wrong.
Any ideas? Thanks friends
      06-16-2016, 05:09 AM   #2
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
Try a new keyfob battery perhaps?
      06-16-2016, 05:58 AM   #3
hks200
11
Drives: N/A
try looking at the battery terminal clamps. sometimes this can be a symptom of a bad earth or bad overall circuit. Had a terminal fracture on one of my old cars which did as you described. Replaced the terminals and everything was right as rain.
Gone--- 02' ABP ITR 6MT | 06' BSM 130i 6MT - RIP | 99' Altezza RS200Z 6MT | 02' WRX STI 6MT
      06-16-2016, 06:52 AM   #4
Fuji
Fuji's Avatar
Australia
97
Drives: SGM E92 335i
If the time is resetting, it might be something causing the battery to disconnect intermittently? Maybe check wiring? How old is the battery?
SGM E92 335i FBO [COLOR="Indigo"]/ MHD Stage 2 Plus / CP-E FMIC / DCI / VRSF DP / VRSF CP / Turbosmart Raceport BOV / BMW PE / H
      06-16-2016, 04:31 PM   #5
reisf
reisf's Avatar
Australia
128
Drives: LBB M2
Yep if time is resetting, it's either the battery, the IBS or wiring to/from the battery. Give your terminal clamps a good scrub with a wire brush to start.
Maybe also try measuring voltage at the battery and at the jump start terminals, if they are significantly different this could be a indication of faulty wiring somewhere
      06-16-2016, 04:34 PM   #6
titium
327
Drives: 2009 BMW 135i
had this on my car. bad battery earth connection make sure the connection is done up tight and terminals are clean.
I was getting a whole bunch of random faults while driving... abs dsc ect ect. right before i went to start it at the shops and it completely shut off like the car was dead couldn't even remove the key or unlock the boot.
tightened the t bolt connection hasnt returned in the past 8 or so months.
      06-16-2016, 11:18 PM   #7
135i2
106
Drives:
If the battery stuff suggested doesn't work check there is no water leak in boot RHS where the access control modules are. Mine got wet and produced similar symptoms. Modules bined and replaced.
135i - RHD Bottom Mount Single Turbo - GTX3584RS
      06-19-2016, 07:44 AM   #8
chrisN
chrisN's Avatar
Australia
30
2010 125i  [8.66]
Taking it in to Advan tomorrow. Hopefully the boys work it out. Thanks keep everyone poster
      06-21-2016, 02:18 AM   #9
dh58
Australia
108
Drives: 135i
Had something similar.. it ended up being something so simple, check the connections. Are they tight? Undo and redo them.
Could also be the battery (my opinion not based on experience). Just charge it up with one of those overnight battery chargers that most ppl are using for MHD flashes?
And the FOB battery.
      08-24-2018, 08:31 PM   #10
E70E90E88
Drives: X5 50I, 328XI, 128I
I have the same issue with my 128i E88, random ZERO POWER and if I just wait an hour or overnight it works again great. I have no ground issues that I can detect with the fluke and power is hot to the front jumper terminal so no clue. Its getting on my nerves to the point I think I am gonna dump the car and move on. Dealer has not been able to find it after four trips to them and once it even did it to them while they had it. They actually said they have no idea and cut me loose with a failed car.
ideas?
      08-24-2018, 09:52 PM   #11
Rajvosa
248
Drives: E92 M3
ideas?
Behind the glove box is the fuse box. Check out the back of it for red battery cable where it goes in. My wife’s car had same issue and it was sparking randomly cutting out power....you could see where it was burnt out.
It was a recall in USA I think but never in Aus. I took it all apart and showed the bmw dealership mechanic and had it done as part of recall.
https://www.e90post.com/forums/showthread.php?t=804545
      08-25-2018, 12:27 AM   #12
Furqwan
Drives: 135i
Just had an issue like this in my car except the whole car was dying. I had to push start it then it was running, drove it abit and everything was going wrong. All electronics shutting off and car started overheating because electrical waterpump shut off, battery voltage dropping. Tried to figure it out testing with a new battery and checking alternator. Turns out to be just the ground wire under the car that corroded away. 8$ later she starts up right away and no issues.
      08-26-2018, 11:10 PM   #13
RadiuM
RadiuM's Avatar
Australia
38
Drives: 135i, 97 GTR VSpec
That power connector issue at the fuse box is a recall, if you haven't had it done yet take it in.
https://www.productsafety.gov.au/rec...motor-vehicles
'09 BMW 135i, Lemans Blue
'97 Nissan Skyline R33 Series II GTR V-Spec
      08-27-2018, 03:13 AM   #14
JBT2
JBT2's Avatar
Australia
36
Drives: 2015 435i
And the problem was...…?
      10-11-2018, 02:05 AM   #15
135BANDIT
135BANDIT's Avatar
Australia
19
Drives: 135 BMT & X5 Msport
good luck trying to get one , apparently the recalled cable has been on back order for the last 3 months .............
