06-14-2016, 01:26 AM | #1 |
Rep 15
6AT Sport / Manual Mode question
Hi Everyone,
Wondering for those with an auto 135i if it's normal that when in manual mode & the car comes to a stop & you don't downshift it will stop in 2nd gear (M2) & will then take off in 2nd gear at every stop / standstill? If I want to take off from 1st in manual mode I have to paddle shift down every time I stop at the lights. Thanks in adance |
06-14-2016, 02:30 AM | #2 |
96
Rep 577
Yep that's normal! I guess it's so the owner doesn't get freaked out when they take off at the lights and don't realise the car will hold in M1 to redline then shift.
SGM E92 335i FBO [COLOR="Indigo"]/ MHD Stage 2 Plus / CP-E FMIC / DCI / VRSF DP / VRSF CP / Turbosmart Raceport BOV / BMW PE / H
06-14-2016, 02:47 AM | #3 |
77
Rep 541
Drives: 2008 135i AT Monaco Blue
Yes mine does this too. Can confirm it's normal.
06-14-2016, 05:06 AM | #4 |
European Editor
10589
Rep 22,992
Its designed that way - for the people in colder climates to take off in 2nd gear say for ice or snow. After all... BMW believes that the driver SHOULD have control over things.
06-14-2016, 06:49 AM | #5 |
54
Rep 472
Drives: Volvo S60 R-Design Polestar
I love that it does this. I find it a quicker launch than with 1st gear as you can launch harder and it keeps traction better, much better for dragging off at the lights : )
I find that if I launch launch hard in 1st I either lose traction (With DSC off) or end up with the DSC light dancing hard and then you need to select 2nd so quickly that 1st ended up being a waste of time. If I feather the launch so as not to break traction or get the DSC light dancing I find that the revs still go up so quickly that I have to select 2nd before I even need it. 2nd gear launch ftw! |
06-14-2016, 08:16 PM | #6 |
Rep 15
Thanks guys!
Just wanted to make sure, I've come from a Golf GTi DSG (nothing but problems with that transmission!), very different beasts but wanted to make sure the BMW was suppose to do that, there's definitely no issue with taking off in second 2nd with all that torque/power at hand. Cheers Last edited by mattav; 06-15-2016 at 02:27 AM.. |
