06-10-2016, 05:10 PM | #1 |
UK F82 owner
599
Rep 677
Lost my launch control virginity
We'll sort of.....
5000 miles over 7 months and I decided it was way overdue to test out this feature in my M4. Yesterday I did my first little burnout pulling away from a standstill, nothing spectacular just turned DSC off and intentionally pulled away with a heavy foot, made a bit of a squeal and little puff of tyre smoke, no incidents...I was happy with that. So with my new found confidence of DSC off driving, I ventured off piste on my route home from Tesco down a generally quiet and straight for miles B road. Stopped the car in a position where I could see there was nothing coming for a good half mile either way and set to task. Sport + Gears lvl 3 DSC off Left foot brake Right foot planted Saw the flag symbol in the display.....getting excited now.... Dropped revs using cruise control to 2500 aaaannnndddd lift off brake Massive and I mean MASSIVE burnout...clouds of tyre smoke everywhere. 90degree left swing, 90degree right swing without exaggerating probably a 5 or 6 second burnout.. I must have moved about 20 feet through all of this. Shit my pants, let off gas and poodled home happy in the thought that I wasn't doing this "at the lights" trying to impress anyone. Not sure what went wrong, tyres were 37 degrees weather was around 17 ish, I guess just too many rpm I'll drop it right down next time I try this.. Just needed to share, I decided telling the Mrs about my antics wouldn't have gained me any brownie points. Lol
His: MY18 F82 individual Verde Mantis, MPerformance aero kit and exhaust.
Hers: MY18 F15 X5 M50D Mineral White on Black 7 Seater family wagon |
06-10-2016, 05:35 PM | #2 | |
642
Rep 1,700
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black Current- 2018 Aventador S. Nereid blue Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i |
06-10-2016, 05:39 PM | #3 | ||
UK F82 owner
599
Rep 677
Try it but make sure you have plenty of wiggle room to fuck it up
06-10-2016, 06:38 PM | #4 |
792
Rep 2,234
How you press the accelerator pedal changes the way LC works. It seemed you activated the "smokey burnout function" (yes, really).
Since we had some time to talk to BMW officials at the Show we simply had to ask them for a bit more info on the matter, like how to use it. As it turns out, it’s very simple. Basically, it’s just like activating Launch Control but with a slight difference. When you activate LC you have to press the acceleration pedal to the floor, beyond the kick down pressure point, however you like. Remember this, it’s important. The Smokey Burnout is activated just the same only that on cars that have this function, they way you press the gas pedal matters. If you press it gradually (slowly) you’ll activate launch control. If you smash it (press it hard and quick) you’ll enter the Smokey Burnout mode and you’ll burn a lot of rubber. http://www.autoevolution.com/news/ho...#ixzz4BDrhgnC6 |
06-10-2016, 07:01 PM | #5 | |
UK F82 owner
599
Rep 677
06-11-2016, 12:02 AM | #6 |
905
Rep 2,651
Drives: M4 Comp Pack
06-11-2016, 01:06 AM | #7 | |
UK F82 owner
599
Rep 677
06-11-2016, 01:30 AM | #8 | ||
905
Rep 2,651
I8 LCI (current)
Mii electric (current) GR Yaris (on order) Lotus Emira (on order) |
06-11-2016, 01:42 AM | #9 |
699
Rep 1,641
This is great info, would love to have seen the attempted launch it sounds epic
I had launch control on the 911 and it was great, it worked every time and didn't have a burn out feature so you could stamp away Will have to try it with the m4 when I get it..
C63 Coupe
06-11-2016, 03:08 AM | #10 |
3531
Rep 11,292
Interesting one to try with the Laptimer app.
If you are going to test LC, you may as well plug your phone in and switch the app on.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
06-11-2016, 03:11 AM | #11 | |
UK F82 owner
599
Rep 677
06-11-2016, 03:14 AM | #12 |
3531
Rep 11,292
Good man. I'd love to see if we could get the M3 0-60 under 4 secs. All in the name of science.
Some in 335d xdrives on f30post have got 4.0secs. We need to kick their asses.
06-11-2016, 03:32 AM | #13 | |
UK F82 owner
599
Rep 677
06-11-2016, 03:46 AM | #15 |
Barge driver
8656
Rep 12,425
M L/C is a load of rubbish, smokey burnout mode? Just make it launch the car!
I haven't bothered with it on mine past experience tells me you're better to just progressively put your foot down.
730d/Z4C
06-11-2016, 04:34 AM | #16 |
UK F82 owner
599
Rep 677
But then you will be looking at my ugly mug not the mess I make of the wheel spin and wasted rubber. I'll do a couple of takes lol
06-11-2016, 04:36 AM | #17 | |
UK F82 owner
599
Rep 677
06-11-2016, 12:46 PM | #19 |
1854
Rep 3,983
Brilliant OP!
I'm starting to drive more and more in the dry with the TC off to point M2 now is set to that rather than MDM now - have now changed M1 to wet press on setting (with MDM most definitely on) and M2 to dry - rest of time just use default setting. Getting fed up with MDM cutting power on slower stuff and really starting to get confidence with the car. Makes a HELL of a lot of difference and the car is so much quicker. Not sure how long rears are going to last at this rate..... Haven't tried LC - must do so in interests of research. Find best to just get car rolling and then apply welly. I avoid S3 as just unsettles things unless you back off momentarily. Must get the vbox on the car at some point....
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
06-11-2016, 01:14 PM | #20 |
3531
Rep 11,292
Wanna see a smokey burn out in an M4?!!!!
Fast forward to 2:07. Those tyre marks look like 50-60 yards long.
M40CCA1437.00 |
