XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      06-08-2016, 05:53 PM   #1
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
X5M oil weight?
Last night I went to pick up oil to top off. Upon researching there seems to be conflicting stories on which oil is RECOMENDED by BMW for this engine. To be FRANK, not rude; I'm not interested in any opinions, I'm just looking for the correct oil for this engine. Can someone with the correct and only answer chime in? Thanks and apologies for the blunt nature of this post but I do not have access to my manual until the weekend and I was hoping for a simple answer from past threads.
      06-08-2016, 06:11 PM   #2
windsailor
windsailor's Avatar
8
Drives: 2013 X5M Black Saphire
5W30 more info first page rest is unwanted discussion
http://www.xbimmers.com/forums/showthread.php?t=477060
      06-08-2016, 06:14 PM   #3
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Yea i read that thread last night and got frustrated when I saw dealers putting different oil in the same engine so I closed it.
It seems 5w30 is the answer. Thanks
      06-08-2016, 07:28 PM   #4
Crazy1323
27
Drives: X5M
Correct
This all started because the older M engines were naturally aspirated and high revving. The required super thick oil, like 10W-60. The S63 does not require this type of oil since oil slinging is not an issue like it is on an S54 or S85.
      06-08-2016, 11:44 PM   #5
RustyX5M
Drives: e70 x5m
Called the (reputable) dealer earlier today and without hesitation confirmed 5W-30.
Common response from (uneducated) shops will state it needs 10W-60 as Crazy mentioned, since they assume its high revving.
      06-09-2016, 01:39 AM   #6
titanle
titanle's Avatar
50
Drives: 2010 X6 Activehybrid
I use royal purple 5w-30 in my N63
      06-09-2016, 07:49 AM   #7
gan23
203
Drives: X5M '18 XM’23 X5 50e 24
Here's a quick way to find the manual
http://www.bmwusa.com/Standard/Content/Owner/dgh.aspx
Pick up your year. There's an addendum to read also.
At page 272, under the heading:
“Approved oil types,” the references
to “Approved” should be read as
“Suitable.” Immediately preceding
the “Gasoline engine” chart, the
following sentence should be
inserted: “Add engine oils that meet
the following oil rating
standards: . . .” The reference to
“BMW High Performance SAE 5W-
30” should be disregarded.
At page 273, under the heading:
“Alternative oil types,” the text
preceding the chart should be
disregarded, and in lieu thereof
should be read as follows: “If an
engine oil suitable for continuous
use is not available, up to 1 US
quart/liter of an engine oil with the
following oil rating can be
added: . . .” The reference to
“specification” should be read as
“rating
xbimmers
