06-07-2016, 08:06 PM | #1 |
206
Rep 1,250
Drives: 20' X3M CP
White smoke when coming to stop.
Hey guys, anyone catless have white smoke come out when pulling up to light.
I don't have the issue at all when driving or on the gas. Just when pulling up to a light. I do use torco full time. Im pretty sure when I just ran just 91 I didn't get this issue at all. But I have to retest. Thoughts? Btw car stats in sig miles are just over 3500 Also trip to work is 4 miles, drive to work, Park sits all day then start and go home. Maybe just condensation... But I don't get it at idle, and I almost never see it on way to work. Just on my way home. Same distance. Weird.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | Last edited by combatbmw; 06-07-2016 at 08:48 PM.. |
06-07-2016, 08:36 PM | #2 |
143
Rep 715
At only 4 miles are you even up to operating temperature? Mine takes a while to get to operating temp, I'm thinking 15 mins or so depending on the temp and speed.
2015 M5 - Singapore Grey Metallic - Silverstone Full Merino Interior - Executive Pack - Drivers Assist Pack -Comp Pack -
06-07-2016, 08:45 PM | #3 | |
206
Rep 1,250
Drives: 20' X3M CP
I just went out with my brother. I didn't see nearly as much smoke. Only the 1st stop nothing like the stops on my way home. Only a Lil bit of smoke. And by the time the drive was over 10 miles there was no smoke. So I'm thinking all the condensation from the morning drive, stay in pipe and on my way home when the pipes heat up, that's where I figure I'm getting the extra smoke. |
06-07-2016, 08:49 PM | #4 |
247
Rep 616
Oil smoke and condensation are 2 different things.
Do you burn any engine oil ? How long have you been running catless and how long do you run Torcu ? Are you running any performance tune or piggy back ? |
06-07-2016, 08:59 PM | #5 |
Hide! My wife's coming!
813
Rep 2,816
I've seen smoke come from the exhaust on WOT. Never at a stop
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
06-07-2016, 09:15 PM | #6 | |
206
Rep 1,250
Drives: 20' X3M CP
Been running catless for a year now. If I was burning oil I'd see it all the time wouldn't I? Pretty sure thats the case. I just went out and once the needle moved on temp I didn't get any smoke..
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | Last edited by combatbmw; 06-07-2016 at 11:22 PM.. |
06-07-2016, 09:21 PM | #7 |
143
Rep 715
If you're oil level is fine and you haven't added any since your break in, I'd say you're fine.
Get it up to temp and do some wot passes and clean that motor out!! Probably just cobwebs! Lol
06-07-2016, 11:21 PM | #8 |
450
Rep 1,519
Your suppose to let that B*tch warm her jelly up. Lol. Never drive a car that the needle is not fully ready. Usually what i do. As soon as i wake up, pull her out start her and go back in the house. And by the time im done about 20mins or so. Car is already warmed up and good to go.
It can be that your car is not properly getting the right driving temp and sometimes seals injectors can actually get harmed by not driving the car longer. That usually happens to exotic garage queens also |
06-08-2016, 10:50 AM | #9 | |
247
Rep 616
I am just trying to clarify if you are seeing condensation during warm up and the cooler weather or if your actually seeing a colored smoke ? Blue and white smoke are different and you would be able to smell engine oil if it was blue |
06-08-2016, 12:54 PM | #10 | |
206
Rep 1,250
Drives: 20' X3M CP
When car is warmed up doesn't seem to do it at all. I really think it's just extra condensation from the morning drive and by the time I get to work the water just sits in the pipes, so on my way home it's just burning off. |
06-08-2016, 04:41 PM | #11 | |
40
Rep 225
06-09-2016, 05:33 AM | #12 | ||
450
Rep 1,519
06-09-2016, 08:17 AM | #14 |
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1090
Rep 1,968
Yours had smoke upon decel on the dyno as well and that's after warm up. It's not vapor.
I think it's turbo seals. |
06-09-2016, 02:26 PM | #15 |
206
Rep 1,250
Drives: 20' X3M CP
May of been just the Torco, some of the guys including Mikes car when he uses torco he gets smoke.
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
06-09-2016, 06:23 PM | #16 |
1090
Rep 1,968
06-09-2016, 10:18 PM | #17 | |
206
Rep 1,250
Drives: 20' X3M CP
I do notice the smoke getting more noticeable when my tank is running lower, by that time the torco mix will be sitting in my tank for 2 weeks or so. This last tank has been in for nearly a month because I did go out on vacation for a week. So maybe the torco after all causes this especially if you are not driving enough. who knows.
06-10-2016, 05:43 AM | #18 | |
184
Rep 788
Your gear box, brakes and tyres will be cold as well... |
06-10-2016, 07:59 AM | #19 |
450
Rep 1,519
Any of those additives really aren't good for your engine long term. They have MMT in them and it leaves these copper colored deposits on the valves and pistons and everything
it. It fucks up sensors and sticks to the metal throughout the engine. Nasty shit Just run REAL race gas instead of trying to cheat with booster. Torco only adds maybe 1-2pts octane pts. btw. Not that 11-14 pts you may see. |
06-10-2016, 10:53 AM | #20 | ||
3388
Rep 7,542
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
06-11-2016, 02:48 PM | #21 |
143
Rep 715
I run a 91 (75%) and E85 (25%) mix. Octane is approx 94.5-95 when combined.
I'm stock except M Performance exhaust and charcoal delete, it runs like a raped ape!!
09-10-2020, 03:57 PM | #22 |
Rep 15
X5m
Hi, my catless x5m f85 makes smoke while coming to stop. It start doing after removing cats and remap. No smoke while accelerating only when coming to stop. Engine hot and outside temperature +20c
