      06-07-2016, 01:29 PM   #1
Gemetzel
Drives: Frozen White E92 M3
Tire wear problem
I have a 2011 135i with the M sport package I replaced the run flat tires for pilot super sports the problem I am having is the out side of the fronts are wearing. Well it seems I have a camber problems but the car has negative camber so the outside wearing doesn't make sense to me. The pressure has been maintained. Any help with this or personal experience with this I would love to hear. Thanks again.
      06-07-2016, 01:32 PM   #2
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
You'll need at least -1.5 degrees to stop the outside shoulders from wearing substantially.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      06-07-2016, 02:07 PM   #3
Gemetzel
Could there be problems with the side wall flexing to much? I am still running the 36/39 pressure split.
      06-07-2016, 03:06 PM   #4
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Not generally the case.
      06-07-2016, 06:16 PM   #5
PrematureApex
840
Drives: N55 X1, N54 135, s54 m3
Hard cornering and minimal negative camber = outside tire wear. You can either add more negative camber or slow down.
While it might help marginally, you can try upping the front pressures a bit...can't hurt.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      06-15-2016, 01:51 PM   #6
VMRWheels
VMRWheels's Avatar
2040
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Make sure your camber settings are within the recommended specs. It wouldn't hurt to try adjusting the tire pressure as well.
