BMW X5 and X6 Forum 2014-Current
      06-02-2016, 02:25 AM   #1
ajob
ajob's Avatar
Monaco
456
Drives: X5 M
Draining windscreen washer reservoir, how?
I got some wrong liquid in the windscreen washer reservoir and tried to drain it by siphoning with a flexible tube.
No luck, as there are too many kinks from filler to reservoir.
Is there a draining plug or another trick, beyond just emptying it with the electric screen washer pump?
BTW, what is the capacity of the reservoir?
      06-02-2016, 06:47 AM   #2
bqvalen
52
Drives: 2019 G05, 2016 F15, 2019 XC60
I did this to my Acura, find the motor and remove it. Usually twists off. I ended up needing a new motor when my mishap happened. Acura part was about $30 so I can assume the BMW one is $120 haha
      06-02-2016, 07:14 PM   #3
alphaod
Mmmmm…
alphaod's Avatar
Drives: F15
You'll need to drain it or remove the fill hose part and then siphon it out.
      06-02-2016, 08:58 PM   #4
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
The tank is sitting behind the passenger side fender.
You may want to try take a peek from the fender liner.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      06-03-2016, 04:52 AM   #5
ajob
ajob's Avatar
Monaco
456
Drives: X5 M
Thank you... yes, it's tucked in there, the top of the reservoir is visible behind a rubber flap but remains inaccessible.
I still have to find a simple way to drain it... I promise to post here a rare Himalaya flying picture if a reasonable suggestions to drain this reservoir is submitted - thank you in advance, whoever!
xbimmers
