06-01-2016, 11:42 AM | #1 |
Rep 14
599M wheels problems
I change my wheels with M performance 599M last month. But when I drive my X5 reach to 75mph, I can feel an obvious vibration. So I go to dealer service center to re-balance all the 4 wheels. The report said they put 15g to 95g to balance the wheels. But when I drive on highway, the vibration still exists, only become smaller. So I don't know that to do to make it right. Any advice is appreciated.
06-01-2016, 11:55 AM | #2 |
3240
Rep 5,066
Tires also cause vibration... Do you have new tires have they been inspected?
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
06-01-2016, 12:14 PM | #3 |
113
Rep 210
Alignment?
I've had the same wheels rebalanced three times until they were finally right. BMW of Alexandria (Virginia) had them all f'd up and it took a German dealership to finally get them sorted out. Point of that story is don't be afraid to take it somewhere else if you aren't satisfied the first time.
2012 328i Sport Line - JB on Coral Red 2016 X5 35d M Sport Line - CBM on Ivory White and Black Dakota |
06-02-2016, 06:34 PM | #6 |
17
Rep 39
Drives: 2016 X5 eDrive40e
There is a good chance that this is a rotor issue. Tires can cause the issue but it is highly unlikely.
06-02-2016, 07:28 PM | #7 |
142
Rep 762
Drives: '23 BMW i7 xdrive60
I had also installed 599M wheels on my X6 3 weeks ago and have had no problems so far. I've driven them at speeds up to 110 mph with no vibrations.
'23 BMW i7 xdrive60 - Frozen Deep Grey
'22 BMW 228xi Gran Coupe - Phytonic Blue |
06-02-2016, 08:30 PM | #8 |
Rep 35
I experienced this with my Vette. I ended up getting someone who knew what they were doing eventually and had a high speed balancing machine. Never a problem again. I'm in Houston and Discount tire was a huge help.
Josh |
06-02-2016, 09:25 PM | #9 |
Self-Deprecating Narcissist
7266
Rep 6,561
is the issue on acceleration and steady speeds or braking? if it is on braking the issue is isolated to the rotors and braking components but if it is on acceleration and stead speeds there are various options to consider. wheel balancing, high speed wheel balancing, road force balancing, or alignment. if they are used tires check direction and wear or plugs/patches that may throw off balance along with "rim" repair that was not properly balanced after reconditioning.
