06-01-2016, 07:37 AM | #1 |
Rep 2
235 width Front with 255 width Rear?
Hi im new to the forum and apologize if this has been posted already but i have a 2010 135i m-sport and currently running a setup 225/40/zr18 front and 255/35/zr18 rear on the stock wheels and they are michellin's. Its time for me to replace my front tires and im wondering if i can go up to 235 in the front and keep the 255 width in the rear?? Im trying to get a little bit more of a wide aggressive look but dont want to lose to much performance. Would this be ok? Any help is appreciated Thanks!
06-01-2016, 09:15 AM | #2 |
840
Rep 2,402
Hard to get a 235 with matching diameter to a 255. People have done 235/265, although technically they're fitting wider than recommended tires for the stock wheels.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
06-01-2016, 10:37 AM | #3 |
Rep 2
Ahh ok thanks! so i guess thats a no :-/ but Id like to move up to 235/265. I love how that looks but i feel ill need new wheels. A shop already told me the size I have now is pushing it and the middle tread is going to wear faster than anywhere else
06-01-2016, 10:49 AM | #4 |
4338
Rep 6,196
Check the specs of the tires compared to the specs of the rims. Tire rack will have the recommended rim width listed for all their tires. Good idea to stay within the recommendations.
06-02-2016, 10:54 AM | #5 |
8
Rep 31
For 135i stock rim sizes 7.5x18 front, 8.5x18 rear, 225/255 IS the max you can go. Confirmed this with Google sites everywhere when I personally made that switch.
06-02-2016, 11:32 AM | #6 |
968
Rep 3,323
Yup, 225/40-18, 255/35-18 are the max. on stock wheels, but depending on the brand the footprint can look wider than other brands do.
My new Michelin PSS have a more squared off look than my previous set of Bridgestone S-04's. Do some reading on this site and you can get good idea as to which brand ...etc. that looks and handles best.
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
06-02-2016, 12:14 PM | #7 | ||
840
Rep 2,402
Plenty of people are running 235/265 on stock wheels. And you can certainly smash on even larger than that (autoxers do, for example) It's simply beyond the manufacturer's recommended rim widths for those sizes. Not that I'd recommend doing it, but it certainly can be, and is, done.
06-07-2016, 08:17 PM | #9 |
112
Rep 1,140
Drives: N54 135i 6MT
What about 225/40 matched with 265/35? Any issues other than a slightly different larger OD?
06-08-2016, 06:26 AM | #10 | |
840
Rep 2,402
So there's that if it matters to you...and the fact that you're introducing even more understeer into an already badly understeering car...if you're concerned about that at all.
06-08-2016, 06:29 AM | #11 |
112
Rep 1,140
I have 18x8 and 18x9 wheels. Just looking for maximum traction as my 255/35 MPSS really aren't cutting it for the street
06-11-2016, 06:01 PM | #12 |
196
Rep 167
I don't run stock wheels but I run 225/40, 265/35 with Michelin PSS and it handles just fine and perfect. And I even got the ECS 28MM solid front sway too.
06-20-2016, 11:04 AM | #13 | |
968
Rep 3,323
225 on fronts. 255 on rears are perfect for this car.
06-20-2016, 07:06 PM | #14 |
15
Rep 187
You're right but a 265/235 will work fine. I have a buddy that runs 265 R888s on a 8.5 inch wheel. I told him no way blah blah but it wasn't as bad as I thought it would be. For most tires a 265 is no biggie on the stock wheels and I've run PSS and V12 EVO in that size on them iirc.
06-20-2016, 07:25 PM | #15 | |
840
Rep 2,402
225/255 are good sizes for stock wheels, but they are far from perfect for this car as a whole. With 50/50 weight distribution, perfect from a handling perspective would be a square setup. The car understeers a ton on 225/255s. From a straight line traction perspective, larger rears than a 255 are more advantageous.
