New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      05-25-2016, 01:48 PM   #1
porshah
porshah's Avatar
197
Drives: M4, R8, Huracan - All topdown
Understanding Offset and Wheel Spacers
Hi All,
I have done quiet a bit of search, but can not find an answer to this. I was wondering if you experts will clarify this for me.
If you have a wheel with 30mm offset and you have a 10mm spacer, does that effectively make your wheel a 40mm offset?
Or say for example, your OEM wheel is 30mm offset, and you want to run 40mm offset without a spacer, is that the same thing?
Appreciate the feedback.
      05-25-2016, 03:04 PM   #2
Bob20124
Retired and Enjoying it
Bob20124's Avatar
Drives: 2011 Z4 35i Alpine White 6MT
good tire comparison calculator http://www.tire-size-calculator.info/
with offsets and visual.
2011 35i BMS High & Low side OCC, Custom tune, CDV delete, Eldor coils, ER Charge Pipe w/Tial BOV, ER Comp. FMIC, K&N drop in,40W LED Halo, LCI side markers, M-Factory LSD, NGK plugs, Racing Dynamics strut brace, Stubby, Windrestrictor
      05-25-2016, 03:25 PM   #3
porshah
porshah's Avatar
197
Awesome! Thank you. Bookmarked.
      06-10-2016, 04:55 PM   #4
UPWheels
UPWheels's Avatar
52
Drives: E60
Originally Posted by porshah View Post
Hi All,
With a 30mm offset + 10mm spacer, your final offset is ET20. So the lower the offset, the further your wheels stick out. To get your ET30 wheel to a ET40, you would have to shave the rear mounting pad of the wheel 10mm. This will decrease the thickness of the mounting pad, making your wheels tuck more, and your final offset will be ET40. Hope this helps. Let us know if you have any other questions.
(The lower the offset, the Thicker the rear mounting pad)
Sales @ UPWheels.com * Ph. 657.888.4UPW * FacebookDOTcom/UPWheels
      06-12-2016, 09:34 PM   #5
porshah
porshah's Avatar
197
Thank you for the detailed explanation. Much appreciated.
zpost
