05-23-2016, 06:07 PM | #1 |
20
Rep 41
Check Engine light on a Canadian 35is
My Yellow Check Engine light came on and the manual doesn't say much about it. It appears to be only on a Canadian Car. Any idea what it means or how to reset it?
All other diagnostic checks are showing ok.
2011 Z4 35is
05-23-2016, 07:17 PM | #2 |
20
Rep 41
Update:
I did some reading and some have suggested a loose gas cap or a vapour lock in the gas tank??? can cause the light to come on. It actually came on shortly I fuelled. My cap seemed tight. I took it off an put it on again. Light went out. Problem solved.
2011 Z4 35is
05-23-2016, 07:39 PM | #3 |
90
Rep 745
A loose (or defective) cap is one of the more common things that can trigger a CEL on just about any vehicle. If it happens again (and it's not being caused by something else), you may have to replace the cap. BTW, what ever gave you the idea that a CEL is peculiar to Canadian models only? I've never noticed one on my wife's 35i, but there are so many other damned warnings that it may be there somewhere and I just haven't noticed it (she has the car right now, so I can't check it).
05-23-2016, 07:43 PM | #4 | |
20
Rep 41
2011 Z4 35is
05-23-2016, 08:38 PM | #5 |
104
Rep 288
Yellow check engine light can be everything. We are not that perfect to guess your problem. So if it is not a loose cap, you have to read the trouble codes and share here so someone can help you
Ar Catless DP, MHD Flash, BMS DCI, ER FMIC, ER CP, Forged DVs
05-24-2016, 07:15 AM | #6 | ||
245
Rep 2,387
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
08-05-2016, 06:00 AM | #7 |
sportscars only
3245
Rep 3,198
Bump and silly question: does the dealer do that for free or what charge will it be? I can't be bothered to buy my own reader.
It will tell you exactly what is the cause of the CEL? It could be as innocent/harmless as not screwing on the gas cap properly? |
08-05-2016, 09:58 AM | #8 |
90
Rep 745
A code reader will not tell you the exact cause of the CEL, but rather the area of functionality (for lack of a better way to phrase it) that is causing the problem. From there, there is procedure for checking various components that may be defective. So it's not a panacea by any means.
tranquility3244.50 |
08-05-2016, 12:27 PM | #9 | |
sportscars only
3245
Rep 3,198
08-05-2016, 10:57 PM | #10 |
19
Rep 125
08-06-2016, 12:40 AM | #11 | |
sportscars only
3245
Rep 3,198
I have a full tank atm. Frustrating but I suspect it has to do w the recall or exhaust sys. |
08-06-2016, 02:10 PM | #12 |
19
Rep 125
Good question Tranquillity. Unfortunately I cancelled my dealership's appointment when the CEL went away so I will never know the exact reason but I recalled two things:
1) the weather was changing a lot (cold then hot then cold etc.) the days before 2) minutes before the CEL came up, I did accelerate strongly in Sport + to inject myself into the traffic. Maybe a sensor was being picky on some pressure variations and when I filled up the tank, the pressure changed. I am not a BMW mechanic though so |
