BMW X5 and X6 Forum 2014-Current
      05-21-2016, 09:32 AM   #1
sssmokie
sssmokie's Avatar
Bulgaria
125
Drives: 2022 G05 M50i with DHP
2022 BMW X5 M50i  [10.00]
2022 BMW X5 45e  [10.00]
2001 BMW X5 3.0D  [0.00]
2015 BMW X5 M50D  [8.66]
Coasting stopped working
Hi,
Yesterday, i decided to switch to eco pro mode for a change and noticed that the coasting function does not work. I checked the driving mode, eco pro mode settings and it was checked. I tried different combinations of unchecking, turning off the vehicle, and checking it back on, but no result.
The only event that I can think of which happened recently was that i got a warning for low pressure in one of the tyres a couple of times. Seems like the front left tyre is leaking, but thats another issue.
So, any help with the coasting functionality would be appreciated.
THanks
      05-21-2016, 11:47 AM   #2
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
Just to be sure, you don't have cruise control on, do you? Try resetting the tire pressures for good measure.
Amber or Red Rear Turn Signals? Vote/have your say: LINK. Post your MPGs 100L/km here: LINK X5 F15 Engines Compared LINK
Take the BMW X5 F15 Survey: LINK See the Results: LINK N57 Diesel Tuning Chips Compared LINK
      05-21-2016, 12:48 PM   #3
Diper
Diper's Avatar
Netherlands
47
Drives: BMW X5 F15 3.0d
It will not coast when the battary is charging.
You probably tried relatively short after start up?
Or was it for the whole drive?
      05-21-2016, 09:15 PM   #4
aw305
aw305's Avatar
Drives: F97 X3MC Alpine White
Is the shifter pushed to the left? If it is it won't work
      05-22-2016, 09:34 AM   #5
sssmokie
sssmokie's Avatar
Bulgaria
125
No cruise control, behavior continues during entire drive, shifter in D
      06-07-2016, 03:27 AM   #6
sssmokie
sssmokie's Avatar
Bulgaria
125
Anyone with fresh ideas on this one?
      06-07-2016, 04:00 AM   #7
Snow-Kidney
69
Drives: F15
Every time I get a tire pressure warning, eco and sport modes are not available.
Did you ever add air to the tire?
      06-07-2016, 04:21 AM   #8
alphaod
Mmmmm…
alphaod's Avatar
Drives: F15
Did you reset TPM after you added air to your tire?
      06-07-2016, 05:30 AM   #9
Colomba
Colomba's Avatar
Sweden
Drives: 2018 F82 M4
How do you know if the car is coasting?
      06-07-2016, 11:55 AM   #10
taxjoc
95
Drives: 2016 X5 50i & 2015 Z4 35i
I had low power steering fluid and that cause a chassis warning. My X5 would not coast when that chassis warning was there. Not sure if this really helps but this was one event when it did not coast.
      06-07-2016, 11:57 AM   #11
taxjoc
95
While in EcoPro mode and when you are traveling at above 30 miles per hour and then take your foot off the accelerator, the engine should drop to idle. It will remain at idle until you either press the brake pedal, accelerate, or fall below about 20 miles per hour.
      06-07-2016, 11:59 AM   #12
Colomba
Colomba's Avatar
Sweden
Drives: 2018 F82 M4
Of course, I'm stupid to even ask, will try an report back.
      06-07-2016, 12:21 PM   #13
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Never knew of this option. Will try it out in a minute.
      06-07-2016, 01:20 PM   #14
alphaod
Mmmmm…
alphaod's Avatar
Drives: F15
Be honest, noticed I'm pressing brakes more since I'm used to engine braking, but with coasting, that's obviously not an option. When you are heading downhill, you go faster and faster. It's great if there is no speed limit you can go all downhill and then save gas on the climbs, but in reality you will be speeding (and cops love to catch folks on a decline). Finally there is no stability control when coasting, so be careful there.
      06-07-2016, 01:30 PM   #15
Diper
Diper's Avatar
Netherlands
47
Just move the gearshifter to the left and it will engine brake instead of coast.
It's easy
      06-08-2016, 04:48 AM   #16
sssmokie
sssmokie's Avatar
Bulgaria
125
I had air coming out of the tire for the past few weeks, but it was just a little, so the warning came on every 5 days or so and i just added more air at the gas station. Only yesterday did I find time to go check it out and sure enough there was a 4cm nail stuck inside. They sealed the gap, but I did not reset the tpms after that as it automatically showed the new pressure.
I guess those frequent tmps warnings might be the reason. I will try resetting them today and see if it works.
Thanks alphaod @Snow-Kidney
      06-08-2016, 08:54 PM   #17
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
But does your coasting counter work?
      06-09-2016, 04:56 AM   #18
sssmokie
sssmokie's Avatar
Bulgaria
125
Update: I reset the TPMs, but still no luck.
Almaretto - I will check later today if the counter works, but the car is not coasting for sure. It uses the inertia to charge the battery, much like in comfort mode.
      06-09-2016, 07:22 AM   #19
taxjoc
95
I forgot to mention that it won't coast if you had cruise control on and tapped the brake pedal. To cause coasting in that case, you have to "blip" (technical term) the accelerator pedal and then it will coast.
      06-09-2016, 07:25 AM   #20
taxjoc
95
OMG! I did not even know we had this coasting display. Learn something new every day!
      06-09-2016, 09:33 AM   #21
Colomba
Colomba's Avatar
Sweden
Drives: 2018 F82 M4
Finally I understand the purpose of that screen
      06-09-2016, 01:39 PM   #22
Almaretto
Almaretto's Avatar
2374
. It can be shown in split screen as well and there is different animation for battery charging.
xbimmers
