New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > E89 Z4 Photos / Video / Media Gallery
      05-20-2016, 12:29 AM   #1
ttuner
ttuner's Avatar
68
Drives: z4
Aftermarket oil cooler?
Might be a long shot, but has anything tried to fit the ER oil cooler in their Z4?
http://www.n54tuning.com/er-sport-oil-cooler.html
http://www.evolutionracewerks.com/node/133
it looks like just mounting and the optional shroud would need to be modified.
2011 BMW Z4 35i | FBO | VTT Stg 2+ (EK, 20T clipped)| Motiv PI| Motiv Tuned | Fuel-IT Stg 2 + inline fuel pump | Spec Stg 3+ clutch | MFactory flywheel | 606whp 575Lbs |
      05-20-2016, 11:08 AM   #2
jts1981
jts1981's Avatar
213
Drives: n54
It looks like it will work. I think there was a dyi on e90 post where some one tested 1 large oil cooler vs 2 smaller. He saved a bit compared to the er kit.
      05-26-2016, 08:07 PM   #3
jts1981
jts1981's Avatar
213
Drives: n54
Any luck TT? I love your build and hopefully will follow suit in the future.
GC LITES / BQ TUNE / MHD / FUEL IT BT ECA / WALBRO 525 LPFP / KW V3 / E9X M3 CONTROL ARMS / TURNER REAR CAMBER ARMS / RE BUSHINGS / H&R SWAYS / LUXON STRUTBAR / VRSF 7.5" FMIC / ER CP / TIAL BOV / VTT IN/OUTLETS / AFE PRO5R INTAKE / AR C.L. DP / BMS OCC / RB PVC / CF LIP + SIDE + SPOILER + DIFFUSER / IND REFLECTORS / BLK GRILLS / STUBBY / PB BBK / Forgestar F14 F: 19x9 et35 R: 19x10 et38/ Michelin PSS F: 245/35/19 R: 275/30/19
      05-30-2016, 11:22 PM   #4
ttuner
ttuner's Avatar
68
Drives: z4
looks like everything out there for the N54 would need major modification to work with our cars, so i decided to go with the Dinan oil cooler, which looks like its the only one made for our cars + the motiv motorsport thermostat delete. i'll probably need some custom lines, but ill figure that out later. its getting to be 110+ here in AZ, so not alot of racing going on right now. car is mostly a meet/car show/garage queen in the summer.
ill post up again when i get it in.
      06-02-2016, 05:15 PM   #5
jts1981
jts1981's Avatar
213
Drives: n54
That's a very cool looking kit. The fit and finish looks pretty good.
      06-30-2016, 04:58 PM   #6
spiicytuna
Drives: e39 M5
I ordered the STETT one. They have custom brackets/mounting etc. for e89 if you email them to place your order.
http://www.shop.stettperformance.com...c?productId=29
      07-03-2016, 05:37 PM   #7
ttuner
ttuner's Avatar
68
Drives: z4
let us know how it fits
      08-03-2016, 03:01 AM   #8
spiicytuna
Drives: e39 M5
FAIL. Brackets do not work.... A big shout out to SSR Performance in Los Angeles for being patient and assisting with the mounting you see below.
After finally coming up with a mounting solution my 300 oil temp canyon runs are no more! So success even though STETT is a total fail with their "supposed" e89 Z4 brackets.
      08-08-2016, 01:35 PM   #9
ttuner
ttuner's Avatar
68
Drives: z4
thanks for the heads up. what all need to be modified?
guess i wont buy till they figure out the brackets.
      08-16-2016, 01:55 PM   #10
spiicytuna
Drives: e39 M5
The brackets provided did not work at all. New mounting brackets will need to be fab'ed. If you want to use the brackets with provide you will need to hack out a section of sheet metal below the passenger side headlight. Even at this point you would need to use a smaller core angled at 45 degrees to make it work. The brackets you see are all custom one off and nothing sent from STETT. Personally I think the "new" mounting location now is slightly better due to more airflow vs the side but now my worry is when I get a FMIC.... but there is actually still quite a bit of room to play with so I should be OK.
zpost
