ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      03-14-2008, 02:46 PM   #1
MakoBimmer1
Booyakasha!
MakoBimmer1's Avatar
Drives: '13 Mini Cooper S Coupe'
Unhappy How to determine correct tire pressures?!?!?
Since replacing my OEM M wheels/tires with aftermarket rims/tires I am unsure of the correct pressures to run. Ive tried 30psi as recommended by BMW for the stock setup, but does not feel right with the larger wheels/smaller tires setup.
Is there an equation to determine correct pressures???
The sidewall on the GoodYear Eagle F1 GS D3s recommends pressures under 50psi but of course Im not going to go near that #. Im tired of testing pressures every other day!!! Thanks to all with real information!
--Chad
'08 M Coupe--AW/IR--SOLD!--My M Coupe Obsession
'13 Mini Cooper S Coupe - My Maui Mobile
'13 Mini Cooper S Paceman- My Maui 'Stuff Hauler'
      03-14-2008, 03:37 PM   #2
Hawkeye
Hawkeye's Avatar
2070
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
I usually go about 2-3 psi under the recommended max pressure of the tire. I have never had a blowout or any other pressure related problem.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      03-14-2008, 03:49 PM   #3
vachss
55
Drives: Z4 Coupe
I like high pressures for autocrossing as it prevents rolling of the sidewall, but driving that way all the time don't you get exaggerated wear in the center of the tread?
      03-14-2008, 04:59 PM   #4
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
you do know by the time tire warms up, it will reach or exceed max pressure. 40psi is not recommended by anyone
I go 2psi above Manufacturer's recommendation COLD PSI btw.
2022 GLE 53 Coupe
      03-16-2008, 04:46 AM   #5
BimmerZealot
61
Drives: 2019 BMW X3 xDrive30i
30 rears, 33 front for me. Or as close as I can get, and as cold as i can manage. Its mostly personal preference, ride quality, handling, etc. Obviously you dont want to under inflate
      03-16-2008, 01:02 PM   #6
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
It depends on a ton of factors...start with the recommended tire pressure for stock tires, and slowly increase it...If I were you I wouldn't go above 35 psi for daily driving...what are the complete tire specs?
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      03-16-2008, 02:51 PM   #7
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
I don't know about Goodyear, but you may want to research their site and see if you can find recommended tire pressures cold/hot. Michelin has recommended pressures for PS Cup tires at 25/27 psi cold front/rear with a target temp of 32/34 front/rear when hot and to change pressures in 2 psi increments when making adjustments. Having a tyre pyrometer also helps, but that is likely going overboard in your situation.
Check out Goodyear and see what they recommend. Probably a good place to start.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      03-17-2008, 06:00 PM   #8
Hawkeye
Hawkeye's Avatar
2070
I usually do my tires when filling gas every now and then so I fill 2-3 psi under max when they are smokin hot
      03-18-2008, 10:50 PM   #9
bosstones
1154
Drives: o_0
With past cars, I've typically gone 31/33 or 33/34 front/rear. I'd say to start with what's listed on your car's plate (& in the manual) and go from there. Generally, I check the pressure cold. If I've been driving, I assume a 2 psi increase from heat so I subtract whatever the pressure happens to be by 2 psi to figure out the cold temp pressure.
      03-18-2008, 11:33 PM   #10
Hawkeye
Hawkeye's Avatar
2070
What kind of tires though. I am running 48-50 psi on my fronts and rears.
      03-19-2008, 12:34 AM   #11
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
307
Drives: '07 M Coupé & '16 435xi GCoupé
I've heard the -10% rule (i.e. 10% less than max stated on tire). I haven't tried it out on my ride, though.
I am currently running 33psi (F) & 35psi (R) on my Generals.
      04-04-2008, 01:55 PM   #12
MakoBimmer1
Booyakasha!
I finally found that 34psi all around works best for me.... So much for some scientific mathmatical equation!
      04-04-2008, 03:22 PM   #13
rosierobins2003
Rosie.....
Drives: 2016 Z4 2.8 Auto....
2016 BMW  [0.00]
what about if you use nitrogen?
      04-04-2008, 04:20 PM   #14
Rick Hunter
307
Don't you remember your own thread? http://www.zpost.com/forums/showthread.php?t=77827
      04-04-2008, 05:20 PM   #15
rosierobins2003
Rosie.....
2016 BMW  [0.00]
hey, sometimes I just try to cause trouble, stir up the dust to see what you guys say. I KNOW that is hard to believe what with my innocence and all.
And I have no middle name, so make it trouble, rebel...whatever you like.
I just re-read that thread...and i was stirring up trouble then too......lol!!
Rosie
      04-04-2008, 09:02 PM   #16
Rick Hunter
307
That's why we love you!
      04-04-2008, 11:22 PM   #17
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
Hmm... I've been wondering this tire pressure thing for a while myself. I've heard figures from 34/38, F/R for stock 18's (staggered), or 32/35, or 30/32 for track, blah blah.....
i would think that with low profile tires, you would want a higher PSI as to avoid denting your rims on potholes. Then again, you risk uneven tire wear if you over inflate.
I checked my tire pressure last week and it was at 30.5/34, F/R. Cornering had felt a bit soft so i inflated it back up to around 34/34 (non staggered setup). Stability seems to have improved, though potholes feel a little more jarring.
2003 Maldives Blue 2.5i -- 18" M6 wheels, 12mm rear spacer, ///MZ4 front bumper conversion, Eibach lowering springs, Koni shocks, Hotchkis F/R anti-roll bars, Helene Performance air filter.
      04-06-2008, 09:12 PM   #18
bosstones
1154
Drives: o_0
Oi! What tires are you running? Is that for street driving?
I use the 31/33 psi for my snow tires (Michelin Alpin 2's) and, in the past, used 33/34 with Pilot Sports (PS1's)...although that was on my ZHP. I haven't had my coupe long enough to have the OE summer tires on for more than 2 weeks. I still got the snows on.
General Exclaim UHP's? If so, how do you like them? I considered those but sidewall flex seemed to be a common complaint.
      04-07-2008, 02:16 AM   #19
Rick Hunter
307
Well... when you get down to the 30 or 35 profiles, the sidewall flex "feels" about the same as OEM Contis with 40 or 45 profiles.
I'm pretty happy with them, and would probably do it again. I figured (at the time) that if they really did suck, then at least I didn't waste too much money (since they're dirt cheap). So far no complaints.
      04-07-2008, 01:03 PM   #20
M2audioman
Drives: 2018 M2
I have 19's on my Z4MC and i'm running at 38F and 36R. Reduces understeer and seems well balanced overall.
      04-07-2008, 01:44 PM   #21
Hawkeye
Hawkeye's Avatar
2070
Yes that is street driving... I have stock RFT tires. The Max is >50psi so I run a few under that usually. I guess I have always been taught to fill when the tires are warm and fill until it is close to the max psi.
Perhaps I'll drop it down another 5 psi (10%) and see how the ride is.
      04-08-2008, 02:00 PM   #22
bosstones
1154
Drives: o_0
lol...I know what you mean. I'm looking at the Goodyear F1 Asymmetrics right now. Was going to reuse the front Pilot Sports from my ZHP since they got plenty of tread and the rubber is still somewhat soft and just buy new rears but....Tire Rack seemed to like the F1 A/S' more than the PS2! They seem promising even though there isn't a lot of reviews that I found on them.
Ah-so, grasshoppa. I've always started with the OE recommendation and tweaked from there and always filled up cold. No biggie.
zpost
