05-11-2016, 09:56 AM | #1 |
59
Rep 244
FS:OBDII CAN Module for F Series
Hey all,
Selling my OBDII CAN Module for F Series. Used for 6 weeks and works great! Only reason I'm selling it is because I'm going the BMS exhaust route. Part is going for $400 (tax and shipping included) on Canadian websites. I'm asking $340 shipped within Canada. Part is located in Montreal. PM or Email me: frcefed579@gmail.com Description from the website: 2012+ F Series Models are equipped with an electronic valve in the tailpipe that helps control the exhaust sound according to a profile programmed from the factory. This handy plug and play module lets you take control of your flapper valve right from the drivers seat. Go from sounding 100% stock to an exotic exhaust system for a fraction of the cost with just one click of a button. Our seamless integration using the CANbus eliminates the need to install/tap wires, carry around external remotes, or physically unplug exhaust components. Just plug the module in to your OBDII port, tuck it under the carpet, and press the turn signal button to toggle between flap always open, flap always closed, and OEM operation. Installation and removal takes only seconds and it won't interfere with aftermarket tuning systems. In addition to control over your factory exhaust valve this handy modules includes many other useful features. For //M models there is an active sound MUTE option to turn off the engine noise pumped through your stereo system. For those with LED headlights there is an LED HALO max brightness mode to brighten your angel eyes at night. In addition there is an optional in dash boost gauge allowing you to read your boost levels when racing. All of these features including the exhaust valve control can be independently enabled or disabled right from the drivers seat! We expect to add many more features to the device via free firmware updates that are loaded at home via a BMS DATA cable. |
