05-11-2016, 07:44 AM | #1 |
96
Rep 397
Reduced Power Engine Malfunction - Diagnosis Thread
Decided I'm going to start a thread on this to hopefully help myself and others with the dreaded limp mode/engine malfunction that randomly happens
I've been getting a Engine Malfunction/Reduced power message every once in a while for no apparent reason, seems to usually happen on the highway during soft acceleration ... I've replaced the following so far in an attempt to remedy this problem, Bank 2 Injectors Bank 1 & 2 HPFP's All Crankcase vent lines Spark Plugs Coils Bank 2 Turbo Diverter valve Bank 1 & 2 Air Intakes Probably a few other things I can't remember right now ... My truck does not throw any kind of check engine light when this happens, just goes into limp mode and turning the truck off and on again makes it go away. It only happens on the highway, usually when I'm going to pass or getting on the on-ramp and slowly accelerating ... It could be that the truck doesn't like to be driving slowly like this so it goes into limp mode as a way to get back!!??! I think this is a software issue with the car itself, I haven't hooked up my computer to the car yet when it goes into limp mode but I'm not even sure if it will register since it doesn't throw a CEL. I know others have similar issues with this and hopefully we can come together and figure out what it is and help each other out here. Just an FYI I have not had BMW diagnosis this and giving the only dealer in my area is a major crook and I DIY it is not worth it for me to waste my money on it for them to tell me everything is fine.
05-11-2016, 07:51 AM | #2 | |
3102
Rep 1,734
Granted, mine was flashing the warning on somewhat harder acceleration runs (by no means WOT). I also noticed that it would reduce the power but would not go into limp mode, per se. Warning would be gone upon restart, like yours. If you have an aftermarket muffler, that's where I'd check next. Hopes this helps, good luck. |
05-11-2016, 08:02 AM | #3 |
1192
Rep 1,546
Drives: '22 Tesla MY + '23 Tesla MY
It may not throw a CEL, but the code could still be stored. You need to get a copy of Rheingold and read the codes
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
Mexcar0070.00 |
05-11-2016, 08:03 AM | #4 | |
96
Rep 397
If you leave them unplugged you loose power |
05-11-2016, 08:04 AM | #5 |
96
Rep 397
I've got a laptop dedicated to this and no codes are stored for this, only thing I haven't done is hookup to the truck when it is active.
05-11-2016, 09:14 AM | #6 |
890
Rep 2,736
Had the same problem and had engine malfunction errors on slow take offs and highway driving while wanting to pass, found it to be the pressure converter and a vacuum leak from a tube going into the unit. Their was a hairline crack in the tube.
Basically what was happening was at slow take offs the vacuum was not strong enough because of the hairline crack and the error was thrown, on hard take offs the vacuum was strong enough that it was registered and l the engine malfunction error didn't happen Part number for my 2012 was 11747626351 Once the tube was trimmed and reapplied the code and engine malfunction disappears. Yay! Not sure as it could be countless issues but I found what your Origanal issues you explained where exactly what I was experiencing and what fixed it for me. Dealers where telling me it was my vanos and a laundry list of much more expensive things and all it was, was a simple tube trim. I replaced the pressure converter just because it was cheap and figured it wouldn't hurt. |
05-11-2016, 09:36 AM | #8 |
Rep 15
engine malfunction
It happened to me once. I started then did harder acceleration and the light came up. Turn off then back on and the light went away. i realize with the turbos it need time so the oil can circulate. before i take off i let the RPM drop below 1
05-11-2016, 10:02 AM | #9 |
96
Rep 397
Diagram showing part "11747626351" and all the hosing that goes with it It is #2 pictured There is quite a bit of vacuum hosing here will investigate this most likely replace the hosing. |
05-11-2016, 11:32 AM | #10 | |
890
Rep 2,736
05-11-2016, 01:10 PM | #11 |
431
Rep 2,062
Great thread! I've replaced injectors, spark plugs, vacuum pump, LPFP fuel line with the updated sensor, and everything in the right picture, stuff in the left picture is sitting on my counter.
The PO had removed and replaced the stock muffler which I noticed because the tips were spotless where the valves were closed, so I ziptied them open but I can't find the vacuum lines to save my life. I swear the power changes by the moment, sometimes it sounds like a Subaru right before I get the reduced power warning, other moments it's a scalded ape...no rhyme or reason. I'll check that vacuum hose mentioned in the above pics because it looks easy until I can find more time this weekend. Travis1807 created a custom intake and CCV lines that'll delete the BMW plastic lines in the top picture, I bought everything from him, but that doesn't solve the rubber vacuum lines. I've looked on eBay for heat resistant silicone vacuum lines, sounds like it's something we should all do regardless since these random issues keep happening to many others.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
05-11-2016, 03:18 PM | #12 | |
3102
Rep 1,734
http://www.xbimmers.com/forums/showthread.php?t=1222381 If you get underneath the vehicle and don't see the lines by the bumper then they may have been removed by the shop that installed your muffler. Not sure if that's the solution to your problem, but... |
05-11-2016, 03:52 PM | #13 |
431
Rep 2,062
I saved your picture from last time, but I've got no lines hanging down at all, so I still need to remove the interior pieces to gain access to where there's supposedly some pump.
05-11-2016, 04:45 PM | #14 |
96
Rep 397
If those lines are left unplugged the truck loses acceleration completely 100% of the time ... I tested this on mine when installing my exhaust.
05-11-2016, 07:34 PM | #16 | |
890
Rep 2,736
05-12-2016, 06:50 AM | #17 |
3102
Rep 1,734
05-12-2016, 10:19 AM | #18 |
431
Rep 2,062
I'll be installing this tomorrow, so I'll look closer then. In the meantime, anyone know what size vacuum line we need because I'd rather just replace it all at this point.
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's Last edited by m5james; 05-12-2016 at 10:42 AM.. |
05-15-2016, 02:06 PM | #19 |
96
Rep 397
Bumping for feedback m5james ....
How is the intake install and vacuum line replacement faired? |
05-15-2016, 02:51 PM | #20 |
431
Rep 2,062
I'm at the BMW 100th Centennial right now, but I'll update more soon. Intake sounds awesome....whoooshhhhh, doo doo doo doo :-)
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's Last edited by m5james; 05-16-2016 at 11:03 AM.. |
belarus277.50 |
05-16-2016, 02:17 AM | #21 |
Tuned ///M Cars Only
143
Rep 337
Drives: '21 F87 M2C |'20 F97 X3MC
05-16-2016, 11:05 AM | #22 |
431
Rep 2,062
The picture with the grills and CF hood aren't mine, but they're just F15 X5M grills you can find on eBay or wherever.
