04-29-2016, 06:54 AM | #1 |
3533
Rep 11,292
335d vs M3 Power and Torque
Had a look over Lorcan's graphs on the AC Schnitzer website for both 335d (which I current own) and an M3 (which I have on order).
I've took the figures for the standard tune of each and came up with these graphs. Here is the source data: M3: http://preisliste.ac-schnitzer.de/ac...40&ID_NR=13596 335d: http://preisliste.ac-schnitzer.de/ac...01&ID_NR=11645 Here are the rather crude graphs I've come up with, but you get the gist of it. Was quite surprised that the 335d actually develops slightly more hp up to about 3500rpm - but develops a lot more torque. So I assume from this that below 3500rpm the M3 will feel a little less potent? But of course after 3500 rpm (which is about half way around the rev counter) the M3 will fly of course.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack Last edited by dopper99; 04-29-2016 at 10:10 AM.. |
04-29-2016, 06:57 AM | #2 |
3533
Rep 11,292
But its not all bad!!
If you look at Sutcliffe's M3 vs Alpina D3 vid where he claims the Alpina D3 is just a nose or so ahead of the M3 on an acceleration test, the figures tell it all really!!!! Below the Alpina D3 (which has about 40 more bhp than a 335d) is at 43mph whereas as the M3 is already at 51mph, thats a fair old lead.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
04-29-2016, 07:22 AM | #3 |
1125
Rep 2,564
The thing that hurts the diesels is that they don't rev high and as a result they usually have longer gearing, which reduces the actual torque available. If both cars go to say 35 mph in 1st gear, the M will have approximately a relative 50% bump in torque (7600 rpm vs 5500) compared to the diesel. Hence why it is faster overall.
04-29-2016, 09:31 AM | #4 |
2712
Rep 2,371
Something is wrong with the horizontal axis on your bottom graph; the numbers don't increase evenly, which throws the whole graph off. Also, HP is just torque*rpm/5252 so if the torque of the 335d is that much great at RPMs below 3k, the HP should also be equally greater, but on your graphs, it is not, it's just slightly greater. So, key point, something is wrong with your graphs.
Regardless, it's well known that diesels have really strong torque down low in the RPMs, and then sputter out at higher RPMs. That's no surprise. Gearing is what is king, though, and as shown, the performance of the 33d is not greater than the M3/4 due to many things, including gearing.
2015 Black Sapphire Metallic 6MT M4
04-29-2016, 09:47 AM | #5 | |
3533
Rep 11,292
I realised the x axis is not linear when I posted it up so you are correct! However, the 2 graph lines for each car up to 3500rpm for power are correct I think, if you look at the source data graphs. This is sort of my point of the thread...... Also good point that gearing comes into it too.
04-29-2016, 10:11 AM | #6 |
3533
Rep 11,292
Ok, I've now made the lower torque graph linear, increments of 500 rpm. I'll sort the power later.
04-29-2016, 10:26 AM | #7 |
642
Rep 1,700
don't forget that peak tq in the diesel only lasts for a 1000rpm or so. so the powerband is short. the M3 has it's peak tq around the same time but lasts for 3650 rpm. in the stock car that is. in the tuned one its peak tq is quite late at 4krpm. that will help with mid range pull, which is exactly what the M3 needs. not early rev torque to creates more wheelspin and traction problems. the penis fizz factor for me is the 50mph to 110mph time being dropped by 1.7 secs
once you have your M3 you wont look back and yearn for the 335d. you'll just want more grunt midrange and be placing an order for an ACS piggy like me!
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black Current- 2018 Aventador S. Nereid blue Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i |
04-29-2016, 12:42 PM | #9 | |
1854
Rep 3,983
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
04-29-2016, 01:31 PM | #10 | |
3533
Rep 11,292
What are your thoughts on wanting to swap it to a 335d? What don't you like about the M4? I see you are in London .... Not much call for a fast car there unless you get out of town!
04-29-2016, 03:32 PM | #11 | |
642
Rep 1,700
04-29-2016, 03:42 PM | #12 | ||
1854
Rep 3,983
04-29-2016, 03:54 PM | #13 |
The artist formerly known as AC Schnitzer UK
3610
Rep 4,518
Another back-to-backer in this morning, this time with an Austin Yellow 14 plate M4, same as ours. Came in for the suspension, went out shaking his head about the power and the exhaust!
There might be some bank robbing going on this weekend |
04-29-2016, 04:25 PM | #14 |
3533
Rep 11,292
Apologies for stealing your graphs Lorcan, but if anyone wants to click on the links in the first posts they can get an idea of how so much better the ACS power upgrade is.
04-29-2016, 04:29 PM | #15 |
3610
Rep 4,518
No problem. The 80-180km/h time is the clincher, and shows in numbers what you feel on the road. It's like a 0-62mph test but with a rolling 50mph start. Sorts the men from the boys
04-29-2016, 05:18 PM | #17 |
Barge driver
8691
Rep 12,437
Dopper old fruit I really do think you're over thinking this, have you driven one yet? If not you can drive mine just to put you out of your misery!
730d/Z4C
04-29-2016, 05:30 PM | #18 |
642
Rep 1,700
Haha... That 'test track' near the queen's country estate is pretty cool... great turns, straights and undulations
04-29-2016, 05:34 PM | #19 | |
642
Rep 1,700
Where in the world are u dopper? More than happy if you want to test drive my cp if there's not one near you?
04-29-2016, 05:58 PM | #20 | ||
3533
Rep 11,292
Arrr dont worry, I'm just amusing myself over data and figures while I wait another 2 bloody months for the car to arrive!!!!!! I believe me, I'd rather have the car and drive it than buggering around with figures and graphs!!! Quote:
But had a passenger ride in Guy's car the other week, so I have an idea what its like.
05-01-2016, 06:09 AM | #21 | |
Barge driver
8691
Rep 12,437
730d/Z4C
05-01-2016, 06:40 AM | #22 |
173
Rep 206
That's horrific, I'd never noticed that before. And he has the cheek to say, "we simply left them in Drive and nailed it."...
