04-20-2016, 11:26 PM | #2 |
166
Rep 710
I'm wondering if they can just be peeled off using a heat gun and some care?
Cars: 2016 BMW X5M. 2017 BMW X1.
Bikes: 2007 BMW F650GS. 2014 BMW K1600GTL Exclusive. 2014 BMW HP4 Competition. 2016 BMW K1300S. |
04-21-2016, 06:54 AM | #5 |
359
Rep 729
04-21-2016, 06:56 AM | #6 |
347
Rep 1,844
After the sticker came off, I cleaned the area with alcantara safe cleaner. Under certain lighting conditions, you can see a slight outline of where the sticker was but 95% of the time, all you see is a blank visor.
04-21-2016, 07:58 AM | #7 | |
18
Rep 84
Could you provide us a Picture of the final result??? Thanks! |
04-21-2016, 11:28 PM | #9 | |
40
Rep 90
http://f15.bimmerpost.com/forums/sho....php?t=1158828 Ive seen a few but they are listed for the M5. |
04-22-2016, 06:59 AM | #10 |
347
Rep 1,844
Here's some pictures. You can see that the passenger side shows a little bit of the outline but the driver's side is almost perfect.
However, I think this is a big improvement over the white and yellow sticker. |
04-22-2016, 07:29 AM | #11 |
359
Rep 729
So, to remove these with isopropyl alcohol, does one just dampen some cloth, or cotton balls, and hold it over the label, and then pick an edge with a finger nail to grab hold of it, and slowly peal it off? The alcohol doesn't damage the alcantara if it gets onto it?
04-22-2016, 07:34 AM | #12 |
347
Rep 1,844
Yes. You need to get the 100% isopropyl alcohol. I soaked a paper towel and put it on top of the sticker for 15 min. I covered it in a plastic bag to prevent drips and to keep the fluid concentrated (it evaporates quickly). Then I lifted up the corner. The passenger side came off almost in one piece while the driver's side required me to essentially tear off the sticker in little pieces. I then cleaned the visors with an alcantara safe cleaning fluid.
Ironically the driver side looked better probably because I had to rub it more. I didn't remove the visors because I couldn't figure out how to do this. If you do that, it will be even easier. Then you just have to vacuum up any pieces of sticker that fell and you are good to go. I let the car sit in the garage overnight with the windows and sunroof open to allow any fumes to exit the car. For my E92 M3, I bought the euro visors. This was much easier and allowed me to keep money in my pocket since the total cost was like $10 for isopropyl alcohol (which I have used for 3 cars). |
04-22-2016, 07:41 AM | #13 | |
359
Rep 729
04-22-2016, 07:47 AM | #14 |
347
Rep 1,844
I used the Sonos brand alcantera cleaner because I have some for my 911 which has an alcantera wrapped steering wheel.
However, any gentle cleaning solution would be fine. In fact, just a damp cloth would probably work. |
06-15-2016, 06:51 AM | #15 |
157
Rep 289
did it :)
Thanks to the graet tips here I did remove the ugly warning labels as well. It was irritating me so much. mostly from the outisde view as I leave the visors open always.
Used "Sticker and DucktTae Removal" spray by well branded DenBraven chemical. sprayed on a little bit, but a lot in to the microfibre cloth and rubbed/peeled it away. perfect. 10min job for both sides |
06-15-2016, 08:07 AM | #16 | |
2038
Rep 1,843
Why didn't you take the M seats ? |
