New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      04-16-2016, 01:00 PM   #1
paris1
90
Drives: 2013 35i Space Grey over Coral
Question Windshield washer problem
My wife (who DDs the Z4) tells me that the washer motor is failing intermittently and I have to believe her even though every time I test it in the driveway it squirts and squirts like there's no tomorrow. She tells me that it will work maybe on the first try and then goes dead after that. Anyone here ever have a failure of this component? Maybe a relay or the column switch?
      04-17-2016, 01:12 AM   #2
ManiacGT
ManiacGT's Avatar
United Kingdom
85
Drives: Z4 sDrive 35i
Never heard of a motor fault but it's a moving part so could fail, more common is gunk in the filter so try cleaning out the water tank filter on the pump first.
      04-17-2016, 05:16 AM   #3
Mick70
9
Drives: Z4 sdrive35i (before: 23i)
Probably "junction box" failure. Read out error messages and you will know for sure.
Best regards
Mick
      04-17-2016, 09:27 AM   #4
paris1
90
Best regards
Mick
How is this done? (No Idrive)
      04-25-2016, 02:21 PM   #5
paris1
90
Best regards
Mick
Mick: Turns out you were right; dealer just called to say the were ordering a junction box. However it didn't throw any codes.
      09-05-2017, 12:03 AM   #6
Tangent
Drives: G01, F82, E89, F25
I know this is an old thread, but was the part they replaced the FRM or footwell module by any chance? I recently stumbled across the fact that my car is covered by the reimbursement offer for that part and a few things have said the windshield washer is controlled by that. I also have a weirdly intermittent washer. Usually when I try to use it I'll get a half second spray and then nothing but shutting the car off and restarting gets me normal operation.
      09-05-2017, 12:48 PM   #7
NoQuarter
Drives: 2008 535xi / 2011 Z4 35Is
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
The JBE is what they are talking about.
Not the same as the FRM
The FRM controls lighting, mirrors, locking and windows
      09-05-2017, 02:21 PM   #8
paris1
90
I had mine replaced under warranty a little over a year ago (see above). I was told by the dealer it would have cost $1k otherwise. The unit is located behind the glove box and is what most other manufacturers call a body control module (I believe).
      09-05-2017, 05:00 PM   #9
distinctperson
Human
36
Drives: 2014 E89 35is
I had the same issue for a few months. The windshield washer pump would work intermittently, and then it wouldn't. Turning off and on the car wouldn't help. Dealer suspected it was algae developing in the tank at first. However, after a quick inspection, turns out that the motor was not fully connected, and hence the erratic behavior. Cost at dealer: $0 (surprisingly!)
      09-23-2017, 03:15 PM   #10
BugsBunny
Drives: 2009 Z4 3.5i, 2022 Macan S
To the people who replied to this tread, two questions please:
1/ Is there any fault code I could look for ?
2/ Does a working pump produce enough noise so that i can hear ?
The windshield washer is not working anymore. I can't hear the pump but to be honest I don't recall I ever heard it.
Thanks
      05-17-2022, 04:37 AM   #11
bryanhoag
Drives: 2013 Z4 sDrive 35i 6MT
Resurrecting this thread as I think I am developing the same issue. Sometimes my windshield washer works totally normally. Then suddenly, doesn’t work at all.
A few questions…
1. Where exactly is the junction box located? Is it on the pull down panel with the fuse box or somewhere else?
2. Does a new junction box need to be coded to function?
Thanks all!
      05-17-2022, 10:42 AM   #12
paris1
90
It’s behind the glove box and yes, it needs to be coded. Mine was done under warranty and I seem to recall my SA saying it was a $1300 job (in 2016 dollars).
zpost
