New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      04-16-2016, 07:30 AM   #1
BMWZ4RIDER
BMWZ4Rider
BMWZ4RIDER's Avatar
Drives: 2009 BMW Z4 35i
Best Solutions to Correct Negative Camber
I need advise form the forum:
1. I dropped my 09 35i with H and R lowering springs.
I love the look but it created negative camber on the rear wheels.
This wil cause the rear tires to wear out in record fast time.
I Have not yet had it aligned and plan to so so but while completing the alignment I found these Negative Camber Correct kits.
I am looking for the Forum recommendations on how you correct this negative camber after a drop.
2nd- I am running my OEM Run Flats with my new VMR wheels.
After the drop the car is ROCK SOLID AND RIDES AND BANGS OVER THE SMALLEST BUMPS LIKE A ROCK.
I know the the RFT's are part of the problem.
Will NON RFT Summer P-Zeros lessen the rock like ride?
Negative camber correction Option 1
Adjustable Bushings
Optimize rear camber to maximize performance or tire wear. Bavarian Autosport's adjustable rear strut mount kit lets you fine-tune camber to suit your purpose, whether it's better handling at the track or prolonging the life of your rear tires--especially important if you have lowered you BMW's chassis or installed 'plus size' wheels. Kit comes with a handy tool for installation and removal of bushings. Range of adjustment is 2 degree's in either direction from neutral.
Option 2
(Click for a larger image)
Rear camber correction arms let you adjust camber incrementally by simply turning the center section. Light, strong and durable, they are constructed from 7075 grade aluminum billet so they are lighter and stronger than the stock arms. Provides camber adjustment from -1.0° to +3.0°. Direct replacement for stamped sheet metal OE arms. Each kit includes two arms and instructions.
2009 BMW Z4 35i/SMG/DCT/Premium,Cold, Sound PK/Com Acc/Ash/PDC/Wind Deflector/Smoked Reflectors/Red Calipers/Cl Mask/M Series Grill/6000K LED's/De-Badged/M Pedals/CF Mirrors-Engine Cover/Stubby/20% Tint/H8 LED's/LCI Side Markers/Sniper Sprint Spoiler/VMR V710/H&R Sport Springs/KN.
      04-17-2016, 08:25 PM   #2
mrkoven
65
Drives: 2016 Z4 35i
http://www.ground-control-store.com/.../II=974/CA=182
Mineral White FBO MHD Stage 2+
Focal & ARC Audio
      09-16-2016, 10:00 PM   #3
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
Call Bav Auto and tell them what you're trying to do. They are the experts and will lead you in the right direction.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      09-17-2016, 10:59 AM   #4
jparnes1
jparnes1's Avatar
245
Drives: 2016 340i, 2012 Z4 35i
Non RFT will definitely help. Be mindful if you swap out the bushings to avoid urethane if you're looking to keep the ride softer.
Also, contact Ed McKernan at www.bimmerbum.com regarding your suspension options. You won't find a more knowledgeable person or better customer service.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
zpost
