03-28-2016, 09:15 PM | #1 |
77
Rep 358
painting wheel advice
I would like to paint a set of wheels black. preferably satin black. Assuming wheels are in excellent condition with their smooth original paint on them can I paint over or will they chip? De they need to be stripped/powdercoated. primed/painted or stripped/primed/painted.
I wouldn't want to put them in too hot of an oven to not alter their structure/rigidity. Don't mean to sound cheap but if a can works does it matter? VHT seems to get good reviews. Primer, spray, clear. Not sure if people shut it down because its from a can or its actually low quality. |
03-28-2016, 11:18 PM | #2 |
340
Rep 1,293
If they are aluminum, I wouldn't strip them bare. Even though it is hard to see, aluminum begins to oxidize almost instantaneously. Any oxidation that forms under the primer/paint will cause the paint to flake, chip, bubble, etc. If the finish on the wheels is in good shape, hit them with 400 grit sand paper or a scotch guard pad. Make sure to get in all the nooks and crannies. This will take the most time, but 95% of a good paint job is prep work. You can use a rattle can, but you may want to ask a paint shop what they would charge to spay them black with a satin clear coat. If you do the prep work, you may be surprised by the cost. In addition, the paint will cure faster and harder compared to spray paint from a can.
One more thing... Make sure to tape off the area where the lug nuts touch the wheel. That area should be bare. |
03-29-2016, 05:36 PM | #3 | |
77
Rep 358
04-04-2016, 05:37 PM | #4 |
19
Rep 709
Why risk using paint? 4 cans of satin black plasti-dip and a roll of frog tape and your gtg. Screw up? Pull it off. Don't like the color? Pull it off.
04-04-2016, 06:15 PM | #5 |
699
Rep 3,267
Drives: 2010 128i
I had a set of mismatched APEX AERO-7's powdercoated to match in Triple Bronze. The powdercoater did sandblast them to remove the original finish. Came out great, IMO. Although it's certainly not the cheapest option, it's worth it to me. Definitely better than Plasti-Dip, which I think is one of the tackiest things going around the car scene right now...
____________________________ |
04-04-2016, 07:15 PM | #6 |
232
Rep 2,643
Respray over old paint generally ends up being a mess. Unless you get them sandblasted and professionally painted, its going to look pretty average and will only get worse over time. IMO its better to sell the stock wheels and use the money for the ones you really want.
04-05-2016, 02:06 PM | #7 | |
77
Rep 358
aeros
please post more pics! those look awesome! |
04-05-2016, 02:41 PM | #8 |
2042
Rep 25,989
I would recommend having them powder coated. It's much more durable than a painted finish.
VMR|Wheels | 714.442.7916 |
04-05-2016, 04:25 PM | #9 |
699
Rep 3,267
Drives: 2010 128i
Take a gander at my build thread linked in my sig for more pics, including a few close ups. I'm currently away from home and don't have access o the files.
04-05-2016, 05:35 PM | #10 |
19
Rep 709
Lots of plati-dip hate! You might be surprised how many cars at shows are dipped. Side to side, there really is no visual difference - particularly with the metallics. If you want permanent, go with powder imo.
04-06-2016, 10:17 AM | #11 |
77
Rep 358
paint
Those look great. The 'hate' for plastidip comes from the 90% of the jobs looking the way they do. its obvious theres a good way to do it but my understanding is since it goes on so thick it is difficult to do it right/the way i want it to look. For an 'oem+' kind of finish powder coat has a much higher success rate
04-06-2016, 12:31 PM | #12 |
26
Rep 149
I've always Plasti-Dipped my wheels.
However, this time I wanted to try painting them. Lots of good info on Youtube. But take a look at ChrisFix for a good step by step demo. Process I used: 1. Cleaned Wheels 2. Sanded major curb rash with Dremil 3. Cleaned wheels 4. Lightly sanded entire wheel including barrel with 800 grit sandpaper (to allow paint to stick) 5. Cleaned wheels 6. Cleaned wheels with Grease and Wax remover 7. Cleaned with cheesecloth 8. Applied 2-3 coats of Primer 9. Cleaned with cheesecloth 10. Applied 3 coats of Satin Black 11. Applied high gloss top coat Advice:
Good luck |
04-14-2016, 06:04 PM | #13 | |
77
Rep 358
paint
My wheels are literally like new. zero scratches/scuffs/curb rash... i guess the first thing to do would be lightly scuff original paint. then prime, then repaint? I have painted many thing before an dam experiences with spray and can |
