03-17-2016, 08:58 AM | #1 |
70
Rep 165
Slight rubbing rear 305 30 20
Got some new tires on the rear on stock suspension, get a very slight rub over bumps, even more evident with a passenger in the car.
Can I have a shop perform an alignment to adjust the rear camber to slightly negative to fully clear the rubbing? Was thinking of lowering the car too but the rear is nice and flush with minimal wheel gap.
2015 F80 M3 DCT : JB4 : Gintani DP : METH : BMS INTAKES : Upgraded Turbos : GTS DCT Flash
11' Z4 35i Procede REV 3 SOLD 2007 e90 335i 6MT:Procede REV 3: Raceland 2.5": VRSF 7":VRSF CHARGE pipe: Walbaro 255 inline: ACT 6 Puck: 100% e85 Garage: 2015 M3 : 2007 M5 : 2016 X1 : 2003 X5 |
03-17-2016, 06:42 PM | #3 | |
70
Rep 165
Wheels are 20x11 rears ET36 305 30 20 20x9.5 ET20 with 5mm spacers Fronts are perfect even lowered, its the rear that has very slight rubbing low speed driving over a bump or unleveled ground (especially worse with a passenger). Should have stuck with the proven 305 25 20, or a 295 30 with that offset
03-17-2016, 07:46 PM | #5 |
216
Rep 1,794
Drives: 06' E90 330, 20' F97 X3m
I'm running 9.5x20 et22 265/30/20 front and 11x20 et40 305/30/20 rear and I'm on KW HAS fully lowered in the front and about 4-5 turns up in the rear from fully lowered. No rubbing to report but haven't tried it w passengers in the rear as I never have anyone back there. Gonna get an alignment soon and kick it in a little. Might even go w the 295 eventually.
LIVE FAST..DRIVE FASTER!! |
03-17-2016, 11:52 PM | #6 | |
70
Rep 165
07-11-2016, 12:36 AM | #8 |
227
Rep 597
I have 305/30-20 in the rear on 10.5" rims with an offset that puts the rim out towards the fender 8.3mm. Then add that I put H&R super sport springs to lower about 1.5".
The top of the tread is up in the wheel well and I cant even stick my pinky between the body and the tire. .... No rubbing with 500lb+ of passengers during full acceleration with my jb4 in map2. Have the carbon roof and the titanium exhaust which is slightly less weight. maybe with a full car and 600lb around some tight corner or bottoming out the shocks. Note I also have the rubber tire stickers that also add another 1-2mm and no rubbing. (but it's darn close.)
2015 F82 M4 Yas Marina & Full SS - All pkg/opts but CCB. Xpel - All painted surfaces
MPerf Electronic steering wheel, MPerf pedals, IND (reflectors, vents, grill, engine cover), Carbon Fiber (side marker, seat backs, shifter surround, e-Brake, rear spoiler). Pure S2 turbos, MPerf Exhaust, Akrapovic DPs, BM3 (Cary Jordan 657rwhp+), H&R springs, 20" AvantGarde rims |
