New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      03-14-2016, 06:44 AM   #1
Carto
Drives: 2011 Z4 35is
Advice on wheel spacers for 35is
I have a stock 2011 35is with 326M wheels. (19x8 in front, 19x9 in back with OEM run flats) Just had them repaired and powder-coated gunmetal grey. They look great, but now I want to move them out. Any advice? Looking at H&R spacers... What size works best for front and back? Any issues? Thanks!
      03-15-2016, 05:11 AM   #2
Mick70
9
Drives: Z4 sdrive35i (before: 23i)
I have only 2x10mm wheel spacers (H&R 2075725) on the rear axle of my 35i with the same 326M wheels. 2x12mm might also fit, but anything more and your wheels will rub against the inner plastic of the fender when driving hard in sharp turns. You can try to form the plastic with a heat gun (or ignore the issue and have the wheels rub the plastic out - e.g. http://bit.ly/1UvuRkA) but I don't like such solution.
On the front wheels you can only add 5mm without modifications of the fender plastic. Unfortunately, the 5mm H&R spacers do not have a center alignment, so it is extremely hard to balance out the spacers on the axle then.
Best regards
Mick
      03-15-2016, 03:02 PM   #3
Carto
Thanks! Not interested in doing any damage, heat guns, etc... Do you think the 10mm you're running really make a difference? Picture? I had thought 12mm on the front and 15mm on the back, but that doesn't sound like it will work from what you say. Again, thanks!
      03-15-2016, 09:49 PM   #4
Wondermutt
Drives: 2011 Z4 3.5i
When I had my stock wheels, I ran 10 mm up front, and 12 mm out back, with no rubbing at all, I was using BurgerTuning wheel spacers, Looked great
Mutt
      03-16-2016, 08:40 AM   #5
Mick70
9
Indeed, I would also have preferred bigger spacers, but I still like the new look better than before. Sorry, no pictures before/after, but I will try to make pictures of the current setup. Advantage: There is no negative influence on the ride with my setup, as I had before with other cars allowing bigger spacers.
On the other hand: Considering that you are living in the US, I believe that you won't see any damages in the fenders with 15/15 on the rear axle and 10/10 on the front axle, unless you regularly do some very spirited driving
Best regards
Mick
      03-16-2016, 07:02 PM   #6
Carto
Thanks for the advice! If you do get a picture loaded, that would be great!
      03-20-2016, 11:23 AM   #7
gnx
Όλα ρόδες
gnx's Avatar
760
Drives: BMW
I have 12MM spacers up front, 10MM spacers in the back on 326M rims, no issues whatsoever.
Tags
wheel spacers
zpost
