03-10-2016, 06:49 PM | #1 |
162
Rep 388
DCT Clutch Lifespan?
DUMB Question, but I need to ask!!!!
Does the clutch needs to replaced in a Dual Clutch Transmission like the manual transmission? Does the clutch wear like the manual transmission? |
03-10-2016, 07:03 PM | #2 |
1882
Rep 3,341
Yes. DCT requires the similar maintenance as a Manual. I believe the clutch wear life is longer however.
Currently:
2018 GT3 2020 X3MC Previously: 1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S |
03-10-2016, 07:17 PM | #3 |
Moderator
7517
Rep 19,368
The DCT clutch pack should last the typical first-owner period with the car and beyond. In the past BMW would not even perform service on the DCT transmission, and I am inclined to believe this may remain the case. It is, of course, possible to have a private shop perform work on the transmission, but you'd want to be sure to use a very knowledgeable mechanic with the proper expertise. I suspect there are very few who are qualified, although I know that some forum sponsors do posses the proper skills.
But, again, under normal use, if you have the car for less than, say, 150k+ miles, you probably won't ever have to worry about it. |
03-10-2016, 09:35 PM | #4 |
21122
Rep 20,741
Drives: 2021 911 turbo
Since DCT uses "wet" clutches (immersed in oil), since there are two clutches instead of one (half the wear on each clutch) and since they are computer operated (not exposed to excessive operator induced slippage), the DCT clutches should wear much slower than a MT clutch. According to BMW, the clutches are supposed to last the "lifetime" of the car.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-10-2016, 10:53 PM | #6 |
Sameet
740
Rep 2,541
Drives: AY/B M4 '15
Even if you needed to replace the clutches, which you most likely won't have to unless you're running >550+ tq, it's not hard.
It took 2 hours to drop the trans and then 5 min to take out the clutch basket. Then off it went to ShepTrans for them to install the Dodson clutch packs which they did in under an hour. I'm sure they would be able to install stock clutch packs as well. Any GTR trans shop can install the clutches for the DCT. |
03-11-2016, 07:48 AM | #7 |
1797
Rep 2,997
I've been impressed by the long-term durability of BMW's DCT transmissions. We've got plenty of examples now over 125k miles as well as running lots of launches and 25-30% more power than stock for many miles and they really do not appear to be a spot that requires any extra maintenance, care, or faces reduced longevity.
In the past, one of the upsides to a manual transmission was a lower running cost over the long-term life of the vehicle. I don't really feel that's a factor with the DCT up to and beyond 150k miles. |
03-11-2016, 08:21 AM | #8 |
14062
Rep 10,081
03-11-2016, 03:02 PM | #10 | |
538
Rep 1,201
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
03-11-2016, 03:08 PM | #11 |
1205
Rep 2,818
BMW DCTs are awesome nowadays. Very little issues and just the normal clunkiness and chatter that's inherent in all DCT setups. It's the SMG transmission that were problematic. These DCTs are STOUT so you shouldn't have to replace the clutch unless you're launching the car at every red light and throwing it into first all the time while coming to a stop THEN maybe you'll cause premature failure..
03-12-2016, 10:17 AM | #12 |
19
Rep 66
Great to know.....not a dumb question
I've always wondered it myself since my SMG clutch in my E60 M5 lasted 100,000km......which was considered average Excellent if this lasts 3 times that (or more) |
07-07-2017, 06:45 PM | #14 |
138
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
A clutch is, by definition, a wear part. So, yes, it would need replacement eventually. I'm assuming when that time is needed it will probably be better just to replace the whole transmission with a new/rebuilt one.
