03-05-2016, 05:37 PM | #1 |
54
Rep 485
Wider wheels cause brake squel
I have a 128i. Stockers are 205/50/17 all around. I notice when i put my wider wheels on 245 rear and 225 front on a 18" setup up my brakes start to squel during breaking. Anybody know the reason?
I guess i need an alignment or camber adjusted?? The squel is less when the brake warm up thou. Doesnt goaway sadly. Doesnt squel at all with my stockers on... Any suggestions?? |
04-02-2016, 09:39 PM | #3 |
840
Rep 2,402
Nothing to do with your wheels/tires.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
04-04-2016, 09:45 AM | #5 |
130
Rep 351
Are you sure the brakes are making the noise and not something rubbing while braking? What are the tire sizes and what are the offsets of the wheels with the 225/245's? Give us more information.
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
04-04-2016, 02:35 PM | #6 | |
172
Rep 2,347
Like Mr E said, give us more info also how many miles on the car were any pads/rotors ever replaced? If so did they use oem or aftermarket? |
04-05-2016, 06:25 PM | #7 |
54
Rep 485
Breyton GTS
18x7.5" ET 45 w/ 225 michelin pilot super sport 18x8.5" ET 48 w/ 245 michelin pilot super sport STOPTECH STREET PERFORMANCE PADS CENTRIC HIGH CARBON PLAIN 125 SERIES ROTOrs in the rear StopTech SportStop Drilled Rotor up front Ive checked my tires and and my wheels. no rubbing marks Once the braking warms up, the sequel goes away. No sequel whatsoever when I have my stockers on. The tire and wheel combo is about the same weight as my stockers, if not lighter. I even tried to isolate the issue and put the breytons on one corner with 3 stockers on, and the squel returns. did this on all four corners... these wheels send off the (!) and DTC light on the dash from time to time too. Both yellow. goes away once you restart the car and drive. Will come back from anytime during a continuous 5km to 200km drive. |
