02-25-2016, 07:27 PM | #1 |
190
Rep 462
Over torqued the oil filter housing by 14 nm, how bad?
I over torqued the oil filter housing by 14 nm, how bad?
So I put another thread up you can see asking about 40nm vs. 25nm. My buddy has a digital torque wrench, so I asked him to set it to 40nm while I was under the car checking on my oil pan plug. He set it to 40 ft-lbs and handed it to me. I SHOULD HAVE CHECK IT! I twisted it (it did not seem to move though). Then when we were putting it away I notice he had it in 40 ft-lbs. (which is 54nm, 14nm more than needed) I freak out and set it to 40 nm. It twists about 2 inches around then the torque wrench clicked. The fact that it moved then clicked makes me feel a little better, but how bad is 14nm over? |
02-25-2016, 10:16 PM | #3 | |
514
Rep 3,482
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
02-25-2016, 11:32 PM | #5 |
42
Rep 266
Some times it is hard to get a real answer around here.
If I am reading right you tried to mistakenly tighten it to 54 but when you rechecked you had less than 40. If so then I would figure no problem. I would check for cracks and then start it and check for leaks. I suppose you could remove the cap and check for problems if you wanted and still re use the O ring. If it doesn't leak I would drive it if it was mine. I can't figure why it bound up the first time you tightened it. You might have saved yourself a leak by rechecking it. |
02-26-2016, 08:18 AM | #6 |
Stop the hate, get a V8
3851
Rep 8,625
It's probably fine, but keep an eye for gasket weeping.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
02-26-2016, 09:15 AM | #7 |
Merlin
477
Rep 730
Drives: 2012 BMW M3 6MT w/ZCP
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i | |
02-26-2016, 05:49 PM | #10 |
3287
Rep 6,729
If you over torqued it, the proper thing to do was to loosen it back up and then torque it again, not retorque to a lower torque value and keep torquing forward.
The cap moving 2" (which is a lot btw) is not indicative of a over torqued cap now being properly torqued. You may have ruined the plastic cap. The seal design of this is a radial seal and not a compression seal, in which case over torquing the cap on to the housing should not matter too much however, with the extra 2" of movement, you may have over stretched the plastic threads and or started to move the lip of the cap in to the oil housing. I spoke to my Engineer (we make similar designed oil caps on buttress threaded housings exactly like these), we test ours to 133% of max torque and then torque to fail. At 275 Nm, the hex starts rounding off so we know you're good there. What you have to be most concerned with is thermal expansion between the Al. housing and the plastic lid. He recommended for peace of mind to 1. loosen and retorque and 2. buy a new lid and replace the o-ring. |
03-14-2016, 10:30 AM | #11 |
339
Rep 1,239
The drain plugs are pretty weak. I didn't know the gasket fell off once and when I put it back on, I snapped the head right off just by barely turning it. I would definitely back it off. On my old E36 M3, the plug was hollow so when the head snapped off, the whole pan would empty!
A job is nothing but work.
03-14-2016, 11:03 AM | #12 | |
514
Rep 3,482
BMWCCA:518970 |
