01-17-2016, 05:53 PM | #1 |
3433
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
ABS Failure at the Track. Flat Spotted Tires :(
So I decided last minute to hit Auto Club Speedway this Saturday. Was a terrific day a bunch of bros there. Nice cool temps and dry track. Some high clouds to begin but gave way to sun. Temps probably 48 deg F in the morning rising to 60 deg F in the afternoon. Couldn't have been better conditions.
This was my first track day in the M3 in over two years. My track tires - NT05s were old, cracking and a little light on tread so I decided to pony up for some Bridgstone Potenza RE71R's. Good thing as when I had the wheels installed the front pads were really low so got some new pads as well. Good to go. Everything was going well. First session just chilled getting the feel of the car and track and then was able to get into the groove session 2 and then I tried to push a little in session 3 as we were gridded by lap times and had a free track. Here's a vid of session 3 which unfortunately was short lived. I was getting ABS warning light all day which is fine if you aren't pushing it. But came in hot for turn 6 and that's all she wrote. Completely flat spotted both front tires which are now ruined. Expensive lesson. Rears are good to go. Car is going to MRF tomorrow to see what's up with the ABS. First issue I've ever had with the car in over 3 years of ownership. Anyway here's the vid if you have 10 minutes of boredom to kill. Lock up is at the very end of the vid if you want to see a one second lock up that will cost me $700.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
01-17-2016, 07:45 PM | #2 |
115
Rep 1,470
ABS light on all day but you kept driving? Good thing I don't ever have to worry about you being behind me on track.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
01-17-2016, 08:59 PM | #3 | |
3433
Rep 6,771
Drives: 2016 BMW i8
01-17-2016, 10:07 PM | #4 |
115
Rep 1,470
You won't be in my group or my wife's group. We are safe.
01-17-2016, 10:18 PM | #5 | |
3433
Rep 6,771
Drives: 2016 BMW i8
01-17-2016, 10:31 PM | #7 |
115
Rep 1,470
Well you won't be instructing, so you won't be in my group. The car you bring does not matter. It is your skill and driving history that matter.
01-18-2016, 09:00 AM | #9 | |
3433
Rep 6,771
Drives: 2016 BMW i8
Obviously with ABS light on I never pushed the car with someone right in front of me. I did when I had an open track no one in front as the vid clearly shows.
01-18-2016, 09:25 AM | #10 |
3221
Rep 6,218
I've had the abs warning come on at buttonwillow before so I came in the hot pits and turned the car off and back on. Warning went away and it seemed fine. It I should get the code read I suppose. I thought I melted a cable or something and checked while swapping my oem pads back on and everything looked fine. I guess I should get it checked out but my braking seemed fine.
One of those exr cars that look like a baby m3 dtm car had horrible lock up in front of me - smoke flying everywhere. Kind of surprised me. How'd you like the re71 initially though? My front right nt01 has a few slits of chording so will need to take an extra tire to the next track day just in case. I'll throw them on the rear right for buttonwillow cw and monitor. Everyone says they grip best just before chording so gotta keep them lol.
01-18-2016, 12:02 PM | #12 | ||
3433
Rep 6,771
Drives: 2016 BMW i8
So I did like the RE71's in the little time I used them. In the same category, I have tracked with PSS and NT05's. Also with RS3's and R888's but those are not really in the same category but still street tires. With 300 tread wear PSS aren't really good for the track, so I would compare RE71's with with NT05's. I didn't get enough seat time to figure out which are better for a stock suspension M3. I did notice a lot of road noise on the RE71's whenever I would drive over a less-than-perfect road surface. Would sound like I was driving through a rain puddle....kinda like the sound of tearing paper. Bugged me if I was using them as a street tire.
01-18-2016, 12:03 PM | #13 |
3433
Rep 6,771
Drives: 2016 BMW i8
Excellent thx for the tip...will have MRF check that out today for sure then.
01-18-2016, 12:26 PM | #14 | |
3953
Rep 3,991
My guess would be a bad speed sensor or a broken connection somewhere. Either way MRF should be able to sort you out.
01-18-2016, 12:38 PM | #15 |
Stop the hate, get a V8
3851
Rep 8,625
My advice would be to keep one of those $30 OBD2-wifi/bluetooth dongles in the car at all times and just pay the $50 for BMWhat/Carly. You could've easily pulled the code during a cooldown session to see if it was something serious or just a nuisance light.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
01-18-2016, 12:47 PM | #16 |
24
Rep 57
Drives: 2017 C7 Z06 Z07 7MT
Welcome to the club! Check your wheel bearing. Mine was going in and out, causing the wheel speed sensor to drop out, ultimately resulting in ABS going out right as I was about to turn onto the road course. I had to get a new hub and I'm replacing the others next month just to be safe.
01-18-2016, 02:31 PM | #17 | |
3433
Rep 6,771
Drives: 2016 BMW i8
1) I assume the tire size did not cause the ABS issue. My new RE71R tires are 255 35 19 F and 275 35 19 R. These are the exact same tire size (Michelin PSS) that I use for daily driving. 2) I do hope it's just a sensor. 3) Excellent thanks for the tip. 4) Yes these tires are trash. But good idea, while the ride is rough they certainly could be used for some ABS testing at least. 5) Great point I didn't even notice that but entirely possible the wheel was turned a little. Yes I was starting tire pressure lower on the passenger side and it worked. Ending tire pressures were the same. I have looked into brake ducting but understand there is no good easy solution. Maybe something has changed I'll ask around. One the Porsche platform everything is so easy. There is a race part for everything. Cheers.
01-18-2016, 05:28 PM | #18 | ||
3221
Rep 6,218
01-18-2016, 05:49 PM | #19 |
3433
Rep 6,771
Drives: 2016 BMW i8
You draw just like my 6-year old!
01-18-2016, 06:16 PM | #20 | |
3221
Rep 6,218
01-18-2016, 06:18 PM | #21 |
3433
Rep 6,771
Drives: 2016 BMW i8
01-18-2016, 07:49 PM | #22 |
1577
Rep 8,077
Drives: 11 E90 M3 Individual
There's a ring on the bearing which is what the wheel speed sensor reads. Sometimes brake dust and other stuff will foul the sensor or the ring.
Hopefully it's just that. Sucks.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
