01-06-2016, 08:04 AM | #1 |
Rep 2
18x8 best tire fitment?
What's up guys, I'm new to this forum but not to the bmw scene. I'm attempting to do a daily/track set up and I need some suggestion from you guys.
18x8 +42 offset all around 245/35R18 all around continental extremecontact dws 06 is the tires I want to go with for the moment. Any rubbing issues? Planning on rolling front fenders slightly more, rears are already rolled aggressive because my current set up is 19x9.5 +45(F) 19x10.5 +50 (R) 225/40R19 275/35R19 Car is also lowered on h&r sport springs, no camber plates. Don't remember my alignment specs |
01-06-2016, 02:28 PM | #2 |
232
Rep 2,643
You are probably going to need some camber plates for the front. The rear will be close. I guess the rear might fit if you can run generous rear camber. The low springs don't help though.
01-11-2016, 05:38 PM | #3 | |
223
Rep 542
Source: I previously ran ET40 square setup, which is pretty close to ET42 (2mm worse).
