12-26-2015, 10:19 AM | #1 |
26
Rep 149
Another fitment question
Hey guys
I'm looking at a used set of Fast Wheels (Canadien brand) and would like to know if these will be flush with my fenders? Info I have: FAST FC04 wheels, 18x9.0 +30, 5x120, 72.6mm hub For the price I might be willing to put some spacers on.... Thanks guys! |
12-26-2015, 10:49 PM | #2 |
219
Rep 361
Those will not fit - offsets are far too aggressive and spacers would only make them worse.
Front is close, you want approximately +33 to +35 (which means the fronts are 3 to 5mm too aggressive already) but you need serious camber to fit a 9" wide wheel. Rears are _way_ too aggressive, you want something in the +45 to +50 range for a 9" wide which means those are 15 to 20mm too aggressive already. Mark
2011 BMW 128i - Check out my STX build thread!
12-27-2015, 01:46 PM | #3 |
172
Rep 2,347
Yeah I agree with above its aggressive for these cars. I'm running 18x9 et38 with 10mm spacer so et28 I have 215s hankooks and I still rub on bumps. I have 18x10 et40 out back with 245s. The fit is perfect I'm lowered on coil overs. Camber is -1.6 up front and -1.7 out back.
