12-19-2015, 10:09 AM | #1 |
491
Rep 1,012
Swift springs batch two hand compression test!
Damn I can't upload the photos from my iPhone ? :/
In short I just tried the same test the other gentleman from NJ tried. I could NOT compress my front batch 2 swift springs nearly as much as he could. And I did the identical methods to him. I. E. I'm also lift frequently, *rep* 335lbs on bench, and weight in at 195lbs. These springs did NOT easily move like that. It's practically confirmed, it's a batch 3 issue* Athough I don't want to jinx myself as I haven't official installed and tested them on my car yet..... Last edited by BMW M4 PWR; 12-19-2015 at 10:14 AM.. |
12-20-2015, 10:58 AM | #3 |
491
Rep 1,012
[IMG][/IMG]
Here are the photo's as promised (they don't show much here in way of evidence, couldn't snap a photo while compressing by myself lol).... I could not compress the "helper" spring portion nearly as easily as M_Driver and the entire spring didn't compress easily under my 195lb frame either... looking forward to installing these to be sure* I don't know what happened with batch three but its not a dimension issue as much as it is the front springs have no spring rate resistance to keep the car off its bump stops issue! Speculation... |
12-21-2015, 05:14 PM | #7 |
Supreme Allied Commander
3876
Rep 54,444
Drives: F80 M3
The helper portion is meant to compress with little effort. It is there simply to keep the spring under tension when the suspension is a droop.
